Grapple Has anyone used Unlimited Fabrications?
   / Has anyone used Unlimited Fabrications? #11
Would you post on TBN or send by PM photos of the two systems you have. Would a diverter system work with my tractor's 21.5 gpm hydraulic flow rate?
Ultimate Fab 72" HD Root Grapple
  • Cylinders-2" bore and a 10" stroke
  • Opening - 36" H x 38" D
  • Steel - 1/2" Grade 50, 3" square tubing, 3" pipe
  • Line routing - Enclosed
  • Weight - 750 lb.
  • Tooth spacing - 9"
  • Recessed grease fittings -
  • Option - Cylinder rod covers
  • Colors - Black, dk. gray, JD green, Cat yellow, orange
  • Price - $1769.00
Skid Steer Conversion - No specs stated, will take about three weeks to fabricate. This one is about $225.00 less than a similar unit offered by another nearby fabricator.
Please let me know if this is built like your HD Grapple. I am a little concerned that the square tubes are 3" rather than 4".
I believe that it is. Mine is the 81" unit. I can't go out and check, it is about a 2 1/2 hour drive to confirm. As far as the diverters, the units I sell are not rated for your pumps capacity, (13 & 15GPM) but you are not using that capacity to operate a grapple. The rated capacity is important when there is a continuous flow and you are not using it for that purpose, are you? I'll see what I can do about some pics, but I don't think that you can PM pics using TBN's system.
   / Has anyone used Unlimited Fabrications? #12
Thanks for explaining the rated capacity/continuous flow factor. I feel even better about my buying decision after you confirmed you have the same style grapple I am buying and that you have been pleased with yours.:D
Please see my PM. Thanks.
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
27017 (A55852)
27017 (A55852)
XCMG CV83PD (A53317)
