xryan
OK, first off, yes battery is fully charged, cables fine, actually just replaced the battery terminals, the old ones wouldn't tighten up enough. Negative cable from frame to battery polished and re greased with dielectric grease, cable ends brushed clean. Key switch also completely disassembled and terminals brushed clean, new grease, etc. +12 to fuses, ALL GOOD. +12 to ignition switch.
Only thing I can think of is last time I ran it it didn't FULLY shut off with the key switch, it ran on at a VERY few RPM's barely enough to keep it going, so I pulled the fuel cutoff knob. The cable works fine, nicely lubed, etc.
A few weeks ago, earlier in the spring, I was doing some spring cleanup getting on and off the tractor when running, etc. My knee smacked into the dash under the wheel, and the tractor shut off. Similar no power to anything as is the case now. Opened up the lower dash to find a huge mess of a mouse nest and two wires that were chewed on the harness to the Time Control Unit for the glow plugs. I assumed that those two wires mush have shorted when I banged the dash. I fixed them and all was well, until this week?
:confused3:
I am really irritated. Any ideas?
:confused3:
