CT 235 hydro trans creep
/ CT 235 hydro trans creep #1
kdill995
gerald, mo.
bobcat ct235
I have a older bobcat CT 235 ( but only 205 hrs) compact tractor with a hydrostatic transmission. Recently the pedal has stopped returning to the neutral postition when you take you foot off the pedal. When you try to start the tractor you have to move the pedal a little to get it into the neutral or Starting positition. When you take your foot off the pedal while the tractor is running, it will start to creep in reverse a little.
Anyone have an opinion of whether this is a big transmission problem or if it might be a easily fixed problem (like lubrication or pedal adjustment that I could make).
/ CT 235 hydro trans creep #2
Why don't you start by seeing if an extensive lube-and-loosen program solves the problem? Linkage is a more likely reason than a hydro failure.
Jim
/ CT 235 hydro trans creep #3
Jim
Welcome to the forum. The above is 100% on target. This happens to lots of us Bobcat owners. Just grease and make sure the linkage is free from debris and I believe all will be good.
MoKelly
/ CT 235 hydro trans creep #4
HST creep is a common problem on Bobcats. I think there are several threads in the forum along with various solutions.
PALLETOF GRANULAR APPLICATORS (A64278)
PALLETOF GRANULAR...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
