Ford 1900 Pto wont engage.
   / Ford 1900 Pto wont engage. #11
You need to adjust the PTO clutch.
Bill
so it looks like the tractor needs to be split to adjust the PTO clutch?
   / Ford 1900 Pto wont engage. #15
got a driveway? :)
hf can set you up with good useable tools for a fraction of the price. most of my larger low use tools are HF... work fine...
   / Ford 1900 Pto wont engage. #16
As described on the first page, sounds like the clutch is stuck possibly due to rust. The reason it doesn't grind without the bush hog on is because there is no load or resistance on the PTO shaft when you put it into gear.
The clutch may need to be adjusted, but try this trick before doing that. Start the mower and get into some heavy grass, preferably heading downhill. Keep the engine at PTO speed. Push the clutch all the way to the floor then let it fly back out. The mower will start to slow down when you push in the clutch and the heavy grass will provide resistance to help break it loose. This isn't as hard of a shock as trying to start the mower from a dead stop, so you won't have to worry about breaking the shearbolt (hopefully). You may have to do this several times. Then try to engage the PTO with the mower stopped. If this doesn't work, then you may have to take it to a shop or look at doing the adjustments as described above.
My dad had the same problem with his 1920 and I think this solved his problem. Haven't had any issues with my 1320 thankfully. Good luck.
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
2015 GMC Arcadia SUV (A50324)
2015 GMC Arcadia...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
