Roll baling advice?
/ Roll baling advice? #1
Birch Hill Farm
Kentucky
International 444
I recently purchased a New Holland 630 4x4 baler. I have never used a round baler before and have no clue on the right method of use, like how fast, what throttle position, and like how big to make the windrows? I have read some where that there is a special method to make a core to get things started? Any advice is appreciated as the tractor im using is marginal in HP Im afraid I will have to go too slow, if there is such a thing.
Thanks for any tips!
/ Roll baling advice? #2
I don't know a thing about that model baler in particular but from putting up hay for several years I will offer my general observations...
You should run the PTO right at 540 rpm. Perhaps slightly more, but no less.
I prefer a nice big wide windrow. With a narrow windrow it is too easy to get the bales bigger on one end than the other, which requires a lot of weaving around from side to side to fix. Another thing I do not like about small windrows is it takes too much driving around to make a bale, I figure it is cheaper to run a rake a little longer and the baler a little less.
As for ground speed, just go slow until you feel comfortable with the operation of the baler. Once you have it pretty much figured out you can increase the speed. You can go too fast, the result will be a loose bale that won't hold it's shape well or in the worse case stop up the baler pick up.
/ Roll baling advice? #3
Believe me you do not want to clog the baler.
Sent from my iPhone using TractorByNet
Thanks for the replys. So going slower equals a tighter bale? and what does one do if they clog up a roll baler? Its an easy fix when that happens on our square baler.
/ Roll baling advice? #5
clog not so easy on round baler.best advice i can give is before starting in the morning wait til all the dew is gone.
/ Roll baling advice? #6
if you clog up the baler youll have to lay down under the pickup reel an digg all the hay out.been there done that,an its a hot sweaty job.since this is your 1st round baler i suggest you have the NH dealer pick it up an go through it an get it field ready/now its costly todo that but will save breakdowns in the field.then i suggest having them come to show you the proper way to run the baler.youll be time an money ahead doing that.
/ Roll baling advice? #7
Stop picking up hay before the overfull limit is reached! :thumbsup:
/ Roll baling advice? #8
Don't forget about those fireants. But I don't think they have that problem in Ky.
/ Roll baling advice? #9
I have found it is easier to dump the tailgate and push the clog from inside out than to pull it out. Not that it makes it anymore fun to do.
/ Roll baling advice? #10
If you don't have a monitor for the baler (may not even had one anyway) you will either have to make some wide rows, like the width of the baler, or do the old swerve method. Like count in your head, to like 8 or 10 seconds then switch sides of the row. As far as rpm of baler, your tractor should have a tac, so rev her up to around 1700 or 1800 and that should be a good starting point. You can go with whatever sounds good. I wouldn't recommend making your baler fly by a wide open throttle. All i have even ran is New Holland balers. I wouldn't go much slower then like 3 mph. Most of the time we run about 5 mph. Maybe a little more. The guys that say they can bale at 10 mph must have some smooth as glass fields. good luck with the baler.
/ Roll baling advice? #11
1. If you don't have an operator's manual, buy one. If you can't find one, ask.
2. Well shaped bales start with the raking job.
3. It's difficult to make good bales with full-width windrows because the middle of the windrow always has more hay than the edges.
4. If you fill the sides of the bale well, the middle will take care of itself.
5. Do not exceed 540 PTO RPM for any reason.
/ Roll baling advice? #12
Rick
I'll second what you stated. Here in the near desert of N. Tx I rake 3 nine ft cuts with a 14 wheel rake laying the 2 outside windrows on top of the center windrow. I normally have no problem making bales level and if I do it's "operator ERROR". I run my baler at 450 pto rpm's, bales are tight and it conserves fuel.
Thanks for the replys! Great advice, I picked up the owners manual as suggested and slowly working through the baler to make sure everything is adjusted and lubricated to spec, so far have had to order the pickup sprocket as the chain was so loose you could take it off by hand and it worn out the sprocket, everything else looks really good. Ran 9 bales through it as we were finishing up some fields of squares I left a little to test out the baler. Couple things I noticed, it clogs fairly easy when starting the core and after the core is started its pretty much impossible to clog, its a major pain to dig out the clog. Also, the manual says minimum of 35 pto hp our tractor begins to bog and die about the time the bale reaches full size and it is rated for 38 pto hp when it was new back in 1971. I found the best way to finish the bales is to time it to be heading down hill when the bale begins to reach full size but, I think we need a bigger tractor. Thanks for the continued advice.
/ Roll baling advice? #14
Measure your bales to be sure they are not over-sized. Too-large bales make the belts run together while moving in different directions and will create an immediate power drain as well as long-term problems. Measure both sides of the bale on both horizontal and vertical axes and average the 4 results.
/ Roll baling advice? #15
My dad acquired a round baler last year, but the only tractor he had with the remotes to operate it went down with an injector pump problem, so our combined experience with them is one partial test bale. (Horse people around here usually prefer the small squares, anyway, so it wasn't a killer, just an annoyance.) The one piece of advice we did get from round baling veterans was to carry an infrared thermometer and periodically check the temperature on the bearings. I don't know how common it really is, but there are plenty of stories about fires being started by round baler bearings getting hot. Rural legends are probably just as bad as urban legends, but the $75-ish I paid for a Fluke IR thermometer seemed like cheap insurance, especially with how tinder-dry things were around here last year.
/ Roll baling advice? #16
What do you recommend for PTO RPM? I have a CI RB454 silage. I try to run around 520 or 530. Is that fast?
/ Roll baling advice? #17
That's fine. A little slower may work jst as well unless you are trying to make 100 or more bales per day.
/ Roll baling advice? #18
We run ours at around 450 to 460 rpm, tach on the the tractor is right at 1800 rpm.
/ Roll baling advice? #19
Thanks. I might slow it down a little and see how it goes.
/ Roll baling advice? #20
When starting the bale it helps to slow speed down until the core starts turning good, then throttle up to pto speed.
86 (A63290)
86 (A63290)
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
