Snow Blower
/ Snow Blower #1
Mikei16
Salt Point NY
Ventrac 4500Y
Hi, I am looking to buy a front mount PTO snow blower for my BX2200 Kubota. Any pro's or con's ?
Thanks
Mike
/ Snow Blower #2
I use the one Kubota makes on my BX1500. A little underpowered but works well. Better on yours Im sure.
larry
/ Snow Blower #3
Thanks
Mike
I just got one with my new BX25 last fall. The machine will really throw some snow that's for sure. I was able to move 20" deep snow without problem. Real wet slushy stuff...not so much. Clogs the chute solid. Also, until you get used where you can and can't go keep a good supply of shear bolts handy. I went through a half dozen or so.
It would be nice if you could drop the blower and mount the fel without removing the quick hitch mount but no dice. All in all I would say if it snows a lot where you are then it's well worth it. If you just get little bit at a time or mostly rain/snow events there may be better ways.
Just my opinion anyway.
Sent from my iPad using TractorByNet
/ Snow Blower #4
Mikei16,
My Dad has the same setup for about 5 years now and it has worked flawlessly over this time. Where he lives they get considerable amount of snow, so it has really gotten a workout. The only thing to maybe consider is the addition of tire chains.
Be prepared to be covered with snow when the wind blows the snow back towards you... Assuming you don't have a cab.
I've used a rear mount snowblower in the past and would never recommend one over a front mounted one if you can afford the increase in price.
/ Snow Blower #5
I have one on my bx2660. Works well. Little hard on the sheer pins at first but I have no complaints. Spend the extra and get the hydro chute rotation
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2012 HEIL (A60736)
2012 HEIL (A60736)
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
