Method for bending past 90 deg?
/ Method for bending past 90 deg? #1
Rio_Grande
When I need things bent I use a local shop who has a press that can bend 1/2" plate. I recently need some smaller pieces bent to 180 deg for a project. 1/8 thickness, 2" wide and each leg is 5 inches long. Basically little triangles. I needed about 16 of them. When I approached my shop owner he said he didn't have any way to bend to the 180 deg but offered to shear the 5 inch legs recommending that I weld them together. While that is an option I prefer that the part be bent as I think it will work better with less grinding in this application.
Anyone have any recommendations for how to accomplish this? Thanks.
/ Method for bending past 90 deg? #2
So, you'd have three 60* angles to form each triangle, is that right? The best way I can think of is to start with a piece of stock maybe 18-20 inches long, and concentrate on getting the bottom of the triangle the correct length. Clamp the stock on the thin dimension (sitting flat) in a narrow vise, then apply heat in a narrow intense band across the bottom of the flat bar and quickly bend one of the "legs" upwards to form a 60* angle. Once you have that bend right, cut the remaining material off of that leg and bend the other one (again using heat to get a tight bend) until it just touches the first leg, then cut it off and weld the joint.
If you linger too long with the heating process you'll have a very gradual, "loose" bend, not what you're looking for. I'd say set the torch to almost the intensity you need to cut with. Two people would be better than one for this, one applies heat the other bends and measures the angle. Since the steel will spring back slightly, you can make up a "dummy block" to fit inside the triangle, one that has an angle of probably about 50-55*. Bend the steel tight to the dummy block and the amount it springs back should give you 60*, give or take.
No easy way to do this that I know of without specialized tooling.
Unless you have equipment designed for those kind of bends specifically it'll be a labour intensive, time consuming process.
Sean
Thanks, the labor intensive time consuming part was why I was hoping to get a 4 foot piece bent so I could just cut them to the 2 inch width. I was afraid a torch may be my only option.
/ Method for bending past 90 deg? #4
Isn't 1/8 about 10 gauge, maybe 11 ? A good hand brake can do that. An old sheet metal shop should have one and i am sure some "tinner" has one in his garage that he uses for a hobbie. The problem is finding him.
/ Method for bending past 90 deg? #5
How about using a log splitter .. I did the same type thing a few years ago,, Make a jig the shape you want and press them into it..
/ Method for bending past 90 deg? #6
Triangle tube ??
To bend three 60* bends you will need an offset box type bend dies.
Then you will have to fixture the parts to close the last angle for welding.
Good luck
/ Method for bending past 90 deg? #7
Some iron railing and gate makers have machines that make some interesting bends in bar stock. I don't know if they'll handle 2 inch widths though.
It is really only. 2/3 of a triangle, v shaped. We have a small sheet metal shop close but he is slow. Like weeks. I hadn't thought of using the log splitter,, that is an idea. I may just cut and weld them. Need to get this done.
/ Method for bending past 90 deg? #9
I'm not understanding the 180 degree bend as that would put the two 5" legs parallel to each other and seperated depending on the inside bend radius. I would think that a makeshift punch and die could be made to fit into a bench vise to create most of the 180 degrees. Then the part could be flattened with the regular vise jaws but, again, I don't understand what the part is supposed to look like after forming.
/ Method for bending past 90 deg? #10
npalen
Not high jacking the thread but I saw your location and I thought I would say hello. My wife's cousin Ernie Porter Is the part's manager at Carrico there in Beloit. Thought you could go by and kick him for me...
Sean
/ Method for bending past 90 deg? #11
If you have to bend all the way around, at angles with small stock, a magnabend is what you need. Unless you build a special bender.
/ Method for bending past 90 deg? #12
It wouldn't be too hard to make a die or "bender" out of angle iron with a section welded to complete the triangle to form on or just flats, welded together for your project.
Weld end caps on the end of the form for the pivot or just tack the part to it and hammer around.
For just a few parts you don't need to get too fancy.
/ Method for bending past 90 deg? #13
npalen
Sean
Sure, I'll stop by Carrico's and give him a kick and then tell him his cousin's husband made me do it. :laughing:
Good to hear from you, Sean!
/ Method for bending past 90 deg? #14
npalen..
Sent you a p.m
/ Method for bending past 90 deg? #15
The shop I work at just uses different dies to bend past 90 degrees.
/ Method for bending past 90 deg? #16
I read the OP's post as he was making triangles or needed to bend completely around something to make the part.
If all he's needs is a "V" any finger brake will work. As they can bend metal to 180.
/ Method for bending past 90 deg? #17
They say a photo is worth 1000 words, so I found a drop of 1/8" plate and made the first bend on my finger brake. Came out at 135 deg on the first bend, remove lower the fingers back down and drop the arm again and your at 180.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2021 ASV 75HD Skid Steer (A64047)
2021 ASV 75HD Skid...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
