Newer Craftsman GT5000 engine won't budge
   / Newer Craftsman GT5000 engine won't budge #1
ErikQ
Princeton, MN
Craftsman GT5000
Make/model 917.289472 GT5000, Serial # 051310A005218
Engine info: Kohler Courage 26hp, SN:4004905773
Here's my problem, I put in storage last fall after changing the oil, draining the fuel tank and checking the spark plugs. I make sure the battery is charged and go to start it up today and the engine won't crank, I mean won't even budge! I try to turn the engine by hand and I find resistance like it's fighting compression. I remove the spark plugs and try to turn the engine by hand again, this time it turns freely. I reinstall the plugs and same thing as before, it won't move. It's only 3yrs. old, I'm kind of at a loss with this.
Any ideas?
   / Newer Craftsman GT5000 engine won't budge #2
pull the plugs and crank it over with the starter for a minute. See if any liquid comes out of cylinders. Then reinstall plugs and try it.
   / Newer Craftsman GT5000 engine won't budge #3
of course it will spin freely by hand with the plug removed. You release all compression by doing this. With the spark plug in, it will be VERY difficult to move by hand depending on what stroke the valves are in for that rotation because of compression. This leads me to belive you have a bad ground and the starter isn't able to draw enough juice to turn it over. do what the other guy said and try to start it without the plug in there. if it does, put the plug back in and take some jumper cables and jump it with your car but take the negaitive lead going to the tractor and ground it to a piece of bare metal on the engine block of the tractor of on the frame. If it starts then either your battery has a bad cell and is trash even though it is reading full. Ill bet that the battery is bad. I have a wheel horse in the garage right now that has to get jumped even if I fully charge it because im too cheap to buy another battery
   / Newer Craftsman GT5000 engine won't budge #4
Any ideas?
Try Adjusting the valves.
   / Newer Craftsman GT5000 engine won't budge #5
The batteries that come in these things from Sears are good for about two seasons. They will test fine with a volt meter, and seem to take a charge, but as soon as you put a load on them they crap out. Try jump starting it with your car, to eliminate the starter as the fault.
   / Newer Craftsman GT5000 engine won't budge #6
May sound silly, but be sure the blade switch is not engaged. I did that by mistake on my Craftsmen. Started up great when I realized I was having a senior moment...
I did think it originally was the battery but I have a 50amp start switch on my charger and tried that, but the gear on the starter just disengaged by spinning up. I'll try to jump it from the car tomorrow and see if it makes a difference.
I read that idea in another post, but it wasn't the case here.
   / Newer Craftsman GT5000 engine won't budge #9
How many volts does the battery have?
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
UNUSED Black Outdoor Patio Fabric Screen Cover (A50860)
UNUSED Black...
Anvil (A50860)
Anvil (A50860)
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
