Front-End Loader can this loader be adapted to fit a JD 855 2wd?
   / can this loader be adapted to fit a JD 855 2wd? #2
front end loader for compact tractor
I know itll probably requires some minor modifications, but what may be involved?
Welcome to TBN.
The main thing would be the length and width where it fits on the tractor. I see the hydraulic oil reservoir, but no pump.
There are some mounting brackets in the bucket, maybe the pump is there too.
Can you run it from your tractor hydraulics or do you need a pump?
The bucket pivot pins show major wear, but that can be fixed.
The front crossmember bolts on, so that would be easy to modify. The arms might have to be modified longer or shorter.
I had to lengthen the arms on my loader put together: http://www.tractorbynet.com/forums/customization/272163-fel-toro-groundsmaster-put-together.html
thanks for the reply and private messages...it's seems that either most people suggest to not fool with it or that if I do it will be a terrible amount of work...so i'm new to the tractor world...what JD front end loader with fit it?
   / can this loader be adapted to fit a JD 855 2wd? #4
The ones that aren't available from JD anymore. I believe the Model 52, Model 70A, and Model 419 loaders will fit/work on the 855. You probably won't find the first two, but you might be able to find a Model 419. Heck, JD might even still offer it. If you can't find one of those three, then your only option is to get an aftermarket like a Koyker, or Bushhog, and there's a couple others as well. Just keep in mind that if you don't have power steering, it will be harder to turn when you have a bucket full of gravel/rock/etc.
   / can this loader be adapted to fit a JD 855 2wd? #5
we can do a kit loader for $1800 new for that tractor
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
