2008 3720 Cab vs 2011 3320 ???
/ 2008 3720 Cab vs 2011 3320 ??? #1
errfoil
Whitefish, MT
JD 3720
Greetings,
I am new to tractors. We are just finishing up a new house on 18 acres of treed forest in NW Montana. I have been thinking about the need/want for a compact tractor for 6 months or so. I would use the tractor initially for landscaping (FEL, boxblade, maybe even a BH). Long term I would use the tractor for log skidding, chipping & shredding, garden tilling, and snow blowing. After the first couple of years I would probably try to sell the BH, and maybe the boxblade.
I have a John Deere and Kubota dealer locally and they both seem like reputable businesses from what I have heard around town.
The JD dealer recently received a 2008 3720 Cab with 450 hrs on the meter. It was traded in by a municipality that used it exclusively for mowing, mostly a side mower for the edge of roads. It visually looks clean, no unusual wear and tear. It has the air seat and wheel wights. The dealership changed out a leaking front seal and replaced a broken front lower window, otherwise they say it is in good working order. They are asking $29.9k, but offered the tractor for $27.5k. There is no warranty available.
The same dealer is getting a 2011 3320 returned from the local 4H club soon with apx 150 hrs. They would sell that one for $21k. It has apx 1 year of warranty left.
There is, of course, any number of new machines available from the local JD and Kubota dealers (there are currently no deals on used Kubotas in my area)
The big difference here of course is the cab. If it seems like I am a bit confused, or at lease un-focused, then you are right. I didn't start out looking for a cab, but a lot of people seem to think they are must-have items, I have also heard that a cab will be a pain in in the butt when I'm running the BH or jumping in and out of the seat while logging. While I'm not sure if the cab is a good or bad thing in the summers, it would of course be the cats meow while snow blowing in the winter. On the other hand, that cab is pretty expensive. If I go aftermarket cab then I have more used tractors to pick from, but then they are not a whole lot cheaper than the factory cab.
My other big concern is used vs new. I don't have any diesel engine or hydraulics experience, so I would be stuck using the dealer if there are problems.
I would love to hear any opinions or personal experiences from those of you with similar needs.
Thanks,
Brett
/ 2008 3720 Cab vs 2011 3320 ??? #2
:welcome:
That's a tough call. The 3720 will have more engine power and the cab may have the deluxe cab options but no warranty and 450 hours. The 3320 is the same frame size but with less power and no cab but does have low hours and warranty left. If the cab option and warranty are the decision makers then you might want to consider a new 3320 cab. you can get a new 3320 cab and loader for around $29,000 and Deere is running 0% for 60 months. Either one your looking at will get the job done. Im sure more guys will chime in soon with more advice for you. :thumbsup:
/ 2008 3720 Cab vs 2011 3320 ??? #3
I wouldn't feel comfortable with a unit used by the municipality and no warranty. Those guys are hard on equipment because they don't pay the bills on it. Why would they trade it in with only 450 hours anyway. That's just my own thinking. I would feel more comfortable with the low hour 3320. unfortunately, that does not have a cab. I was out mowing fields and moving mulch the past 2 days in disgustingly hot and humid weather and I was in a very cold comfortable setting with my cab so I couldn't imagine not having a cab at this point. Although I did do it without a cab for many years. it sucked. Sounds like the cab wasn't that important to you in the first place so I would recommend to you to go with the low hour machine. the 3320 is a stout machine with plenty of power
/ 2008 3720 Cab vs 2011 3320 ??? #4
When did you buy a FEL
/ 2008 3720 Cab vs 2011 3320 ??? #5
When did you buy a FEL Short throw?
just got it mounted last week bro haha. started using it Monday.
heres some video from a day ago I took
/ 2008 3720 Cab vs 2011 3320 ??? #6
and then I took the loader off to mow today. You will get a kick out of this video
/ 2008 3720 Cab vs 2011 3320 ??? #9
Those prices are venturing into "new" territory pretty closely. I'd do a bit more looking around before jumping at either tractor!
However, as CinderSchnauzer mentioned the hours are really a non-issue (450 hrs. = 3-4 oil changes) and while you can have a few "summer-hire" knot heads on a city crew there's not a lot that kids are gonna do while mowing residential or other municipal properties. Nearly all municipalities have service contracts with the dealership's that they purchase or lease their equipment from; so, they're on a maintenance schedule as well.
While 18 acres is enough work (especially with trees) to keep you busy for a few years; you'll be spending as many hours in the tractor seat outside of the woods as in the middle of them. Especially after the first 2-3 years. Get a cab tractor -- you're living in Montana... ;)
If you have time, go look the tractor's over; sit in the seat, work the controls. It can help with the decision-making process! :laughing:
Best of luck.
AKfish
/ 2008 3720 Cab vs 2011 3320 ??? #10
I would go with the 3720 cab. Take an oil sample and send it to Blackstone labs - this can tell you if there is any wear based on the metals and elements in the oil - I do this on my larger farm equipment and my diesel trucks.
/ 2008 3720 Cab vs 2011 3320 ??? #11
Another vote for cab!
Already been down the OS road and that's no longer an option. IMO, 450 is nothing on these tractors. I'd just give it a good looking over/test drive. Then don't look back.
/ 2008 3720 Cab vs 2011 3320 ??? #12
Im taking delivery of my 3320 cab this coming week. Im going from a 2320 open station because I cant handle the dust and grass anymore. I would mow for 3 hours and then have sinus problems for a week. For me the cab option is cheaper then a week in the hospital for having pneumonia. Like others have said , once you get a cab you will never want to go back to an open station.
Thanks for all the great replies. My first reaction to hearing this was a municipal machine was the same as yours; an employee that could care less about wear and tear. A couple of friends have chimed in and told me that these are great jobs and that people would be worried about losing their jobs or not getting hired next summer if caught abusing the machinery. Now the 4H machine is scary because if I was a kid I'd probably tear the **** out of the machinery just for fun (we were all stupid as teenagers, right?)
I have read that mowing or field work is a lot less wear on the tractor than loading with lots of back and forth work, hydraulics cycling all the time, etc. Any opinions on this concept?
I've been watching the local market all winter, and there is just not a lot of used tractors for sale in my neck of the woods. When I first started looking at tractors last fall I told my JD dealer to call me if they got in any good used machines. He said "we almost never get any used compact tractors because people just keep them, they never sell them". I chalked that up to salesman BS, but after 6-8 months I'm starting to think he was being honest.
I just checked out Tractor House, Machine Finder, and the like, and all the new 3720's are in the high $30k's, so I figure buying a 450 hr machine is saving me about $12k. Is there someplace I'm not looking that you recommend? There is a Kubota dealer called Barlows that a lot of the orange guys swear by. They buy tractors from them from all over the country, is there a JD outfit like Barlows?
dschuffert, do you do this with both the tranny and the engine, or just the engine? I'm actually more concerned with the hydrostatic transmission than I am with a diesel engine.
Once again, thanks to all of you that posted replies. They don't exactly give these tractors away so it's nice to hear all this feedback, especially on the cab (although it looks like you guys are going to cost me some money:))
Several of you recommended taking the machine for a test drive. At the risk of sounding like an idiot, what do you look for? Is there a good checklist somewhere? I would look for leaks, cracks and dings; but the engine and the hydraulics are the items that cause the most concern, and I'm not sure how you differentiate between a 'clean one owner' and an abused piece of junk. I fly airplanes for a living so I have a good conceptual understanding of hydraulics, but we also have defined operating parameters for test flights; minimum cycle times for specific tasks like flap extension, minimum pressures while under specific loads, etc. Anything like that for tractors?
/ 2008 3720 Cab vs 2011 3320 ??? #18
That's a good question. I wasn't thinking about the tranny. I just do this with the engine but you could do it with either or both.
/ 2008 3720 Cab vs 2011 3320 ??? #19
Go for the 3720, definitely check the oil, but note, you will appreciate the turbo when you have the AC running and are cutting grass up a slope or picking up something heavy in hot weather. That i the reason i went with the 3520 - the additionla power when you need it.
/ 2008 3720 Cab vs 2011 3320 ??? #20
same here, the time lost fighting the pollen and the dust being recovered is well worth the cost. Plus the Sirius radio, the AC, the heat, ah the convenience.
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2024 John Deere 4044R Tractor (A63116)
2024 John Deere...
2007 Gravely 260Z 60in. Zero Turn Commercial Mower (A61567)
2007 Gravely 260Z...
2000 KOMATSU GD530A-2CY MOTORGRADER (A62129)
2000 KOMATSU...
2007 JLG 600S SKYPOWER TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
