Traction MF65 Diff Lock
   / MF65 Diff Lock #1
oilystairs
Member
Faget Abbatial, France
MF65 Mk2
Hi,
I have never been able to get the diff lock on my 65 to work and i wondered if it is just my operation. How do you put on and take off the lock. I know which lever it is but it has no effect if i push it down or pull it up. It may well be busted but i'd rather check before looking for a repair.
Thanks
   / MF65 Diff Lock #2
Hi,
Thanks
Step down on the pedal after the wheels stop spinning to engage. To disengage release diff lock pedal, depress clutch to release or turn right or left or apply the right brake according to the owners manual.
I worked for a Massey dealer back in the 70's and had a customer step on the diff lock pedal while the wheels were spinning and tore things up pretty bad. The head mechanic removed all the chunks from the differential case and disabled the lock due to the high cost of repair at the customers request. possibly the same but you will never know for sure without tearing it down. Could be something simple too, I haven't looked at the parts breakdown.
You may not know its engaged unless you have the tractor pulling hard, with it engaged, and not seeing one tire spinning faster than the other.
   / MF65 Diff Lock
Hi, thanks for that - i think it is broken because nothing seems to move or engage when i step on it. I'll add that to the list of work needed. Cheers
   / MF65 Diff Lock
Namyessam, as you are someone in the know; may i pick your brains - i did a radiator flush because the engine overheated and since then i discovered a very slow drip of coolant from the water pump pulley. I was planning on taking out the water pump and refurbing it. Is there any other cause or any extra work i should do while i have the pump out? I'll probably replace the hoses as they are 50 years old and looking pretty well worn. Thanks
   / MF65 Diff Lock #5
I am not familiar with a 65 but some things are similar enough.
Good time to change the thermostat. You should remove the radiator before removing the water pump. It will make the job easier and protects the radiator from damage from wrenches and other tools while removing the pump. While you have the radiator off, be sure to clean all the fins of dirt to insure good air flow though the radiator before reinstalling it. Use a good quality antifreeze.
namyessam
   / MF65 Diff Lock #8
Just curious. Where you a mechanic when you worked for Massey Ferguson dealer?
I guess it all depends what your definition of mechanic is. If I have given incorrect information here please correct me.
namyessam
   / MF65 Diff Lock #9
namyessam
Sorry if you feel offended by my question. I just asked a simple question because you stated you worked for MF back in the 70's. you are not obligated to answer the question. FYI, I never implied in any of my messages that your information was wrong. Please show me if I implied that. You where backing up your advice by stating you used to work for MF. Your words not mine. Good day.
   / MF65 Diff Lock #10
I was not giving advice when I stated I work for a Massey dealer, I described damage and a repair that I witnessed personally.
Unused Delta Crash...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
7ft Double Legs Lifting 5/16 G80 Chain Sling (A49462)
7ft Double Legs...
