Soapandbacon
I've had enough of poison ivy, oak , sumac ... Until I get a few goats around here , has anyone been successful in eradicating these plants from your property ? If so how? And what are the side effects ? Thanks
Not getting rid of but controlling it. I use this
Shop Roundup 32 Oz. Poison Ivy/Tough Brush Killer Plus Concentrate at Lowes.com
It seems to kill it after a few days. I spray a few times a year around the trees in the yard that had it bad and after a few years I only get a few plants popping up every year. The wood line is covered in a few spots and I would go broke trying to spry that
Stuff in the link was a concentrate mixing of 12 tablespoons per gallon.
Salt water works well for me.make up some saltwater and dump it on the poison ivy- kills the plant.
Stoypoint would I mix that from TS or apply it straight. I have a rather large patch at the woodline I would like to get rid of, but cost has always stopped me .
The labels for 41% glyphosate say to use 2% of the chemical per gallon of water. This equates to 2.67 ounces of 41% glyphosate per gallon of water. So, if you wanted a 5 gallon mixture, you would add 13.33 ounces of the herbicide to the water. The labels also say "For control. Repeat applications may be required to control. Fall treatments must be applied before leaves lose green color."
At $50 per 2.5 gallons, 41% glyphosate costs $0.16/ounce. Thus, a 5-gallon mix would cost $2.08.
Steve
