aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I might try using the a bar across the 3 point to lift while pulling forward, get the front end of the dumpster off the ground and pivot on the back...They came to pick up the dumpster, but the truck driver said he could not pick it up because the column was in the way. Something about snapping his cable if he tried?
I got my tractor and gave it a shot from just past where the lawn was seeded with a 100 ft chain. No dice. I even had the front wheels on the road, trying to find grip. I had the chipper on the back, and loader forks on the front, so about 14,000 lbs in 4 wheel drive with a locked rear diff.
I was only able to move the dumpster 2" or so. Will have to try again once the ground dries up some.
Aaron Z
