Rotary Cutter Is this a bad idea that's going to damage my tractor or me?
   / Is this a bad idea that's going to damage my tractor or me? #21
I pull a 48" King Kutter rotary cutter behind my Kubota B3300SU. Some of my mowing is maintaining woods in a brush free condition and I find the 48" width highly maneuverable. I do not consider KK in the class of Woods for implements but my 'hog, which I rebuilt after finding it as a carcass in the grass, has never given any trouble after I replaced multiple missing frame components. It whacks through 1" to 1-1/4" brush fine. KK and I have worked together 18 months and I have never broken a shear pin.
In terms of mowing up hill in REVERSE: be very careful. There is an enormous amount of inertia energy in the moving blade of a rotary mower. When you are pushing it up hill, the mower weight shifts towards you and the tractor, you DO NOT then want to encounter a stump with the rotating blade which could flip the mower over toward you on the seat. With the 3-Pt. Top Link holding the mower down, you should be fine but be careful. And keep the PTO shaft lubed, so it can shorten without binding as you mow in reverse. I use Fluid Film in a spray can on the two PTO shaft sections.
The B-series Kubotas do NOT have Position Control controlling the 3-Pt. So to maintain an even cut, with no scalping, you will probably want to buy a set of Zerco check chains. Link below to thread I authored in February 2013. With Zercos and proper adjustment of the cutter, you can achieve a pretty smooth cut.
http://www.tractorbynet.com/forums/...271185-kubota-b3300su-zerco-check-chains.html
   / Is this a bad idea that's going to damage my tractor or me? #22
I have a older 48" Landpride bush hog that I find very versitile. I have used it to cut trails thru saplings an inch or so in diamater and 6' tall. I use it to maintain my trails and cut the grass around the cabin. As others have pointed out, the cut may be a little uneven, but for me it's good enough. Can get used for a good price. My tractor is smaller (TYM233) but never had an issue using the hog. Good luck.
   / Is this a bad idea that's going to damage my tractor or me? #23
Just some comments FWIW:
* That is a light-duty application. Any used rotary mower off Cragslist that is in good working condition would be sufficient, you don't need to spend what a commercial landscaper would pay for an implement he uses daily in much tougher use. Save a thousand $ and buy your wife something nice. You're not going to wear out a decent used implement in your application.
* Backing up that many times to edge that field 4 (or 5) ft at a time will drive you nuts. Can you use the existing mower to do most of the edge, and the rotary mower backing into the edge 1-2 times/year to knock down jungle encroaching into the lawn?
* I think I would try to grade the perimeter so it is safe to run the rotary mower along most of the border.
   / Is this a bad idea that's going to damage my tractor or me? #24
It doesn't look that step to me. You say you have a FEL. Use your FEL and a rear blade, scrape it ever direction you can to get rid of the brush. Then mow it with finish mower.
I extend my yard and paths into the woods by doing it that way. Cut the trees, scrape it and then mow it.
Just be careful to go up and down, perpendicular, on the grades you're worried about not parallel.
I pull a 48" King Kutter rotary cutter behind my Kubota B3300SU. Some of my mowing is maintaining woods in an brush free condition and I find the 48" width highly maneuverable. I do not consider KK in the class of Woods for implements but my 'hog, which I rebuilt after finding it as a carcass in the grass, has never given any trouble after I replaced the missing frame bits. It whacks through 1" to 1-1/4" brush fine. KK and I have worked together 18 months and I have never broken a shear pin.
If you are pushing it up hill, the weight will shift toward you and the tractor, you DO NOT then want to hit a stump which could potentially flip the mower over toward you on the seat. With the 3-Pt. Top Link holding the mower down, you should be fine but be careful. And keep the PTO shaft lubed, so it can shorten without binding as you mow in reverse. I use Fluid Film in a spray can on the two PTO shaft sections.
The B-series Kubotas do NOT have Position Control controlling the 3-Pt. So to maintain an even cut, with no scalping, you will probably want to buy a set of Zerco check chains. Link below to thread I authored in February 2013. With Zercos and proper adjustment of the cutter, you can get a pretty smooth cut.
Thanks for the info about the check chains, that's good to know! Looking at your picture, your B3300 is the same width as my B3200. Maybe I need to reconsider the size of the mower and look at a 48" size. I'm not mowing hayfields, as you can see in my photos, I'm looking at mowing between trees. The 48" may be a better fit. I can still knock down the grass in the "pasture", it will just take a little more time.
The other upside to the 48" mower is that it's lighter than a 60 by almost 200 pounds, so that's less stress on the tractor.
   / Is this a bad idea that's going to damage my tractor or me? #26
I mow 6acres of field with my 72" Kodiak cutter. This is an area we mow once a month as well depending on rain. The skids dig in once in a while but once you get use to it and tweak your height setting you can eliminate that. I was very surprised how clean of a cut I am able to get with it.
   / Is this a bad idea that's going to damage my tractor or me? #27
As was mentioned earlier the mowers with suction ( an upward bend near the tip) will cut the brush and also give a smooth cut on the grass. I had a finish mower and sold it because the rotary cut so well. Some of the smaller cutters only come with the straight blades and the grass cut is poor. Just something to consider when making the decision. I bought a 4 year old used bushhog 6 foot cutter for 700 on craigslist in very good condition.
   / Is this a bad idea that's going to damage my tractor or me? #28
My 7' Kodiak rotary cutter has an amazingly refined cut for a big brush cutter. It will cut pretty close too, but the skids do dig in if it is set too low.
   / Is this a bad idea that's going to damage my tractor or me? #29
re: removing the FEL and adding a front weight: Depending on the tractor, that can be a major ordeal. On my old M4700, the front weight bumper had to be removed for the FEL. Getting it back on meant properly aligning and holding steady a 100+# weight while threading the bolts in. It took either a tall jack or another loader to hold it while bolting it on.
   / Is this a bad idea that's going to damage my tractor or me? #30
https://www.youtube.com/watch?v=WK-_mF1XUK0
Teikas Dad
Here is a sample of what I do with a Woods BB48 cutter. I had a LandPride RCR 42 that I used with my b2620 and BX25. The process of hooking up the Woods is far simpler than the LandPride. I have good luck with the Woods mower. It has both a slip clutch and a shear pin. I have no love for slip clutches. Except on tillers.:2cents::D
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2018 ASV RT30 Posi-Track High Flow Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
