Help Removing Knob
/ Help Removing Knob #1
kcender
Nova Scotia
GR2120 B2650 Cab
Does anyone know how to remove the knob on the TPH lowering speed control?This is on a B2620.It is the black knob that is between your feet if you are sitting on the tractor.I would like to remove the plastic trim piece to lube my loader control valve but this knob is preventing me from removing it.Any help would be appreciated.
/ Help Removing Knob #2
On my BX, it is just friction fit. A lot of friction, but that's all.
That is what I was thinking but it doesn't seem to want to come off.I pulled on it with all my strength but it didn't move.It looks like there may be a set screw on the backside of it but it is hard to get a good look at it.I was hoping someone might know.
/ Help Removing Knob #4
Try looking it up at Messicks, they auto-email parts diagrams
Thanks for the tip on Messick's,good for future reference.I downloaded the parts diagram but it doesn't show much,looks as if the knob just pushes on from what I can see.
/ Help Removing Knob #8
If all else fails, try using the knob when you're out mowing deep grass. It will fall off for sure and you'll run over it with the mower.
/ Help Removing Knob #9
I had to remove that knob recently and it is a bear. I used a pry bar up against the plastic body work with a piece of wood for protection and worked the knob from on side to the other. It was hard to believe that it was just a friction fit with how much force it took to get it off but it truely is only a friction fit.
/ Help Removing Knob #10
Use a open end wrench the same size as the rod. Place the wrench behind the knob and pry with a bar or tap with hammer. I've done both. The wrench reduces the chance of damage to the knob.
/ Help Removing Knob #11
Heat gun or hot water will do the trick. Most are a basic poly and press fitted on a flat shaft that has barbs to aid retention.
L.O.L., mine also falls off from time to time as a previous poster mentioned. Slip the claws of a hammer over the shaft and pull.
/ Help Removing Knob #13
There must be a women around there who has had experience with knobs...:p
heat gun or hair dryer will do the trick
Tried using a heat gun,worked like a charm.The knob came off with a good tug.I had to tap it back on so I don't think it will fall off.One thing to do is put a wet rag around the knob so as not to melt the plastic trim piece.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
7102 (A61567)
7102 (A61567)
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
02GER CHICKET HOUSER 240' (A62131)
02GER CHICKET...
Linde H35D 4,350lb. Diesel Forklift (A61567)
Linde H35D...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
