pclausen
Cabinets are in.  I must say I'm not particularly thrilled with the quality of the cabinets, nor the quality of the install.  The quality of my Ikea cabinets at one third the price are nicer than these IMHO.
Sigh, not again... This is one of the most prominent spots in the house
Those upper cabinets flanking the windows should have been a few inches wider
And the framing is off here. Originally there was not to be a cabinet here. That was changed after the drywall was already done
They should have framed a 45 here. Also, the framing should have been a good inch further in to be flush with the cabinets.
You can barely see the receptacles and switches being so high. You have to literally bent down to see them when you are standing at the counter top.
Wonder how they are going to paint the tie panels to match the rest here? Hopefully they have some veneer they plan to put on that matches the rest. Also, the dual oven clearly won't fit in that tall cabinet. I guess they will have to take out one of the drawer or something.
Just don't know about the construction of the base cabinets
Hopefully the drawers can be adjusted to correct
That corner door sure is sagging compared to the fake drawers under where the sink will be
Fake corner they added behind the lazy Susan.
One of the "book shelves" is chipped pretty bad
And this shelf has several of these nicks all along the lower front edge
Closeup of hinge. No where near the adjustment possibilities of my Ikea cabinets.
The guy that put in the under counter vent way back when, apparently did not know the distance to the toe panel. So once they cut back the tin, if left a nice spot in the floor that needs a tile piece fitted to it.
I suppose I'll let them complete the job, adjusting all the doors and drawers, but I see several things that no amount of adjustment will fix.
Also, as you can see in some of the pictures, the painters haven't been back yet to do the trim or final coat of paint. With the cabinets in place, that will be more challenging now.
