jumpy clutch , mostly in reverse at high rpm, up a slope
   / jumpy clutch , mostly in reverse at high rpm, up a slope #1
canadianstrom
Kioti DS4510 HST, Kubota GR2100
I have been bothered by a the clutch ds4510 HS . While releasing it at high rpms, in reverse and backing up a hill , I get some crazy jumping of the clutch. It is like it goes from from a nice easing into motion to full speed then back to no engaement of the clutch, repeat untill I am cursing and the tires have marked up the soil. I am doing my best to ease it out for a smooth start. I have checked the trans fluid level, it was ok but I topped it up a little over the mark on the stick ( thinking by being on a slope maybe it was a little short). No better.
I do have considerable tractor experience ( over 30 years, probably put over 10,000 hrs on loader tractors, never had to pit a clutch on any of my tractors). I am certain that once the jump gets going, I make it worse because I'm getting pitched back and forth. If I ride the brakes it does smooth it out. At low and mid rpm I can do nice starts with the tractor. I have operated some tractors that were much harder to ease away from a stop but none had this jerky off-on behaviour.
I am wondering it goes from the slipping phase to full engaged too quick and my foot is causing the disengage from getting pitched. I have tried bracing myself ie seat belt tight, both hands on steering wheel, other foot firm. That did not help though.
I think it is worse once the machine is fully warmed up.
Any ideas?
I appreciate any thoughts.
   / jumpy clutch , mostly in reverse at high rpm, up a slope #2
Maybe out of adjustment? How many hours?
   / jumpy clutch , mostly in reverse at high rpm, up a slope #3
I don't understand why you would want to forward/reverse at high RPM's.
Use the foot throttle and lower the RPM's to forward/reverse
   / jumpy clutch , mostly in reverse at high rpm, up a slope #4
The hydraulic shuttle is not designed to be changed at fast revs or when the tractor is moving at more than a crawl. (ie when the tractor is under load )
On a hill , slow the revs down , throw the shuttle into neutral while touching the foot brake to take the load off and come to a stop , then push the shuttle fully to the opposite direction and rev up.
I do not use the hand throttle much when mowing on hills.
Thanks for replies.
it is 2years old with about 180 hrs ( it's just a hobby tractor) . Its done since new, the 100 hour service was done by dealer which includes the tran hyd fluid change I believe. The clutch travel is good ie it disengages well before the pedal hits the floor and engages with a couple of inches of travel left. I am pretty certian the clutch is good. the fact that it lets me ease it out in the forward direction also makes me believe the clutch is adjusted ok.
I am usually bush hogging or snow blowing, I am doing a lot of direction changes and don't want to be moving without the implement running at full speed. I am clutching , stopping , switching direction and releasing clutch.
   / jumpy clutch , mostly in reverse at high rpm, up a slope #6
My DK 35 has a shuttle shift.
I finish mow and brush mow with it often. I use the foot throttle and lower the engine speed when I want to shift or forward/reverse. Works much better .Smoother and easier on operator and machine.
I never saw any need for the implements to be running full speed when I forward/reverse. Just harder on equipment and makes the tractor jumpy and more difficult to control IMO.
(APPROX. 20) 4' X...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
9000 (A47477)
9000 (A47477)
5011 Ford F-550 (A55973)
5011 Ford F-550...
