Rear Finish Mower can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #1
coffeeman
Hi all,
Any help appreciated
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #2
Hi all,
coffeeman....You know what I did with mine....I went to the John Deere dealer and bought 5 tubes of 00 Cornhead grease and filled my gearbox on my Bush hog brand bush hog with that...It is and has always worked just fine and has no leaks...you can Google corn head grease ...it is not expensive....Just what I did...
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #3
I replaced a seal on a Woods Cadet shreader. The hardest part was getting the blade holder off the shaft. I borrowed a 2 jaw puller from our dealer for that.
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #4
Done a few seals on gearboxes and it is not too bad. Once the blade is off it is fairly easy. Just take your time and puller and heat will make getting the blade off much easier. Just make sure when you replace the seal you get it in straight to start!
Good luck
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #5
The gearbox/support plate/drive pulley assembly must come off the deck as a unit after the belt is removed from the drive pulley. The assembly will weigh somewhere between 80 and 100 lbs, I'd estimate. Then the pulley must be removed to access the seal and stake nut. Several dealers have online parts diagrams; a search will easily bring one up.
Other posts referring to blade removal are incorrect; no blades have to be removed.
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #6
Opp's - Rick is right - finish mower not hog. Same general idea but in a way even easier. Good catch Rick
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #7
I happen to own an RM990 and replaced both gearbox seals before putting the mower away last Fall.
Right on the money. I liked the idea of cornnead grease. I tried power steering fluid and grease. I hoped steering fluid and grease would plug things up. No work. I then did what I shoulda done to begin with. I shot out and picked up a new seal and for 2 bucks I bought a new snap ring just in case we crap up the one in machine. My son-in-law jumped in and took apart. No pullers and nothing hard to do. Pulley came off easy. Seal was easy. One thing, as you mentioned, gearbox and pulley must be taken off together for easy going. I did watch only, as I don't have pick up power after a long hospital stay. My strength inproves most every day. Overall, changing seal on Woods rm990 is easy compaired to what I thought it might be. Woods is a good machine.
Cheers....Coffeeman
   / can anyone estimate difficulty to replace seal on gearbox Woods finish mower rm990 #9
RickB is bang on. Only other thing to be sure of is to use some emory clot or sand paper to get the rust off the shaft and oil or grease the new seal before you slide it onto the shaft.
Abe.
Abe.
Did that. One thing comes to mind, though. While attempting to Mickey Mouse things with grease and steering stop leak, I wonder if residue of power steering stop leak might hurt new seal somehow. Stop leak was about 1/2 leaked out during trial "fix it" run. I would guess it shouldn't hurt new seal. However, I think the reason stop leak works is because it's made to swell the old seal. I wonder if I should change gearbox grease or is that over kill? When job was done, had to add a quart 90wt to full up.
By the way, don't take comment toward Mickey as a knock against him. He is one of my favorites. Always smiling and in a good mood. A nice guy to have around.
Cheers....Coffeeman
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52128)
Gooseneck...
2014 Dodge Avenger Passenger Car, VIN # 1C3CDZAB4EN223470 (A50324)
2014 Dodge Avenger...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
