pros and cons of net wrap ?
/ pros and cons of net wrap ? #1
peabody
hello .. can someone tell me if theres a huge difference between net wrap and twine ?
im thinking of buying a 4x5 baler for 80 acres of fescue ..im in west central mo.
how much does net wrap cost compared to plastic twine ?
I've heard net wrap is faster... but im not too concerned about speed.. or should i be ?
my old NH850 chain baler is plumm wore out.
im going to be using a NH tn60 tractor..about 48pto.
thanks
/ pros and cons of net wrap ? #2
1st the netwrap feature adds about $3000 to the cost of the baler.the netwrap cost $200 a roll wich is about $5 a bale added cost.ive heard alot say the netwrapp os a pain when it doesnt wrapp right.
/ pros and cons of net wrap ? #3
I don't know how big bull figures the cost of his net wrap but it is not $5
Net wrap has many advantages
1. time that your baler is running while it is wrapping...that is is wearing on the side of your baler and those belts or chains are turning that many more revolutions to wrap with twine
2. net wrap balers have better resale potential
3. net wrap shed water much better than twine
4. the cost of the net wrap is closer to $2 per bale not $5
5. net wrap bales hold together better if moving several times
6. the only advantage of twine baler is that they are cheaper to purchase
hey thanks guys .. ...ok ? a roll of net wrap is around 200 dollars...
how many bales can you wrap with a 4x5 baler ?
/ pros and cons of net wrap ? #5
with two wraps about 120 to 140 depending on the length of the rolls
so if i splt the difference ... say its three dollars a bale... theoretic should be 66 bales ... am i close ?
ahhh ..ok .. didnt know there was different lengths of rolls.
/ pros and cons of net wrap ? #8
I am not wrong on the cost
we do about 10,000 5x6 rounds a year
/ pros and cons of net wrap ? #9
Some of these were already mentioned...
The only down sides to net wrap are extra cost of the baler and the wrap, having to remove the net wrap and dispose of it when feeding.
Net wrap hay does keep much better than twine when stored outdoors, is worth a bit more when selling hay, doesn't take nearly as much time to wrap as twine and doesn't fall apart when handled several times.
thanks ...im looking at a rebel 5410 .. they say ? my little tn60a with 48pto .. will run it ok.
....they say .....
been looking for a new holland 488 or 472 ....
/ pros and cons of net wrap ? #11
It might be able to, but I wouldn't want to.
/ pros and cons of net wrap ? #12
The only disadvantage for me with the wrap is that by the time I dump it in its spot and can walk around it four or five times to unwind the wrap, I'm fighting cows and trying to keep from getting trampled. If its twine I can usually cut across the bottom with my pocket knife quickly and go around to the other side and pull em out before to many cows get there. Of course y'all may know a better way.
/ pros and cons of net wrap ? #13
We bale 3000 odd bales a year (hay and straw) to sell and personally i still use twine for cost but baling straw behind rotary combines on a dry year net is nice to hold the bales together as straw is smashed up very short and occasionally a twine bale will just bust open as soon as it leaves the baler ...The hesston 3x3x8 big square balers seem to bale it ok when it's like this !
/ pros and cons of net wrap ? #14
I figure around 200 bales per roll for 4x5 bales and product cost of around $1.25 based on a 10,000 foot roll at $235.
A generous wrap of plastic twine will run about $0.25 per bale.
/ pros and cons of net wrap ? #15
Ever try a good sharp knife on the net? Cuts as well or better than twine.
Just think how many times you would have to walk around that bale to unwind twine!!
/ pros and cons of net wrap ? #16
I bale with a JD 467 and my netwrap costs less the cost of twine is about $1 per bale. In addition to what rancher1974 stated about netwrap if one can raise bale off the ground to cut netwrap it's much easier to remove from bale than twine. Netwrap is about 25% faster baling time which can add up especially if it's looking like it might rain. If one is selling hay it gives the bales eye appeal to help sales.
/ pros and cons of net wrap ? #17
Go with the net wrap. Its so much faster, looks better, wastle less, and sells better if your selling it. If you're feeding it or plastic twine wrapped bales, be sure to take it off the bale and out of the field with you. I make most of my living doing contract work on other peoples property. Plastic wrap and plastic twine have cost me thousands if not tens of thousands in repairs from that stuff left in fields and wrapping up on unseen shafts on my equipment. Even final drve seals on two of my tractors, one combine, and both sides of one dozer were eaten up with this twine and wrap.
Like i said get the net wrap, you will be very pleased with it. Sorry i got a lil sidetracked there.
ok..ill go with the net wrap.
im pretty sure I'll be happy .. from what all of you are telling me.
thanks
/ pros and cons of net wrap ? #20
That is what I get with a roll of net wrap and that's wrapping 3.25 times
Sent from my iPhone using TractorByNet
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A62129)
2020 CATERPILLAR...
1607 (A57192)
1607 (A57192)
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 DRAGON ESP...
2012 VANTAGE TRAILER PNEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
2016 FORD F-250 (INOPERABLE) (A60736)
2016 FORD F-250...
