old tar removal
/ old tar removal #1
daveinnh
Gold Member
Hillsboro, NH
Kubota L4310
My wife bought a used Miley horse trailer; frame is Haulmark. The trailer has extensive tar-spot splatter (maybe from driving thru a road crack sealing project?). I can remove most of each old "bubble" using an old plastic ATM- credit - other card, but residue remains.
The trailer sides appear to be plastic laminate over plywood or OSB?
She's tried bug-removal spray with no success.
Any suggestions on residue removal?
/ old tar removal #2
Going to sound crazy but I have used Mosquito spray with good results, its also good for stains in clothing, scuff marks on floors etc.......once you quite laughing, give it a try.:thumbsup: Deep woods off seems to work best.
/ old tar removal #3
if its tar based .. engine oil on a rag should remove it.....
/ old tar removal #4
Try Goo Gone, my dog tracked in some roofing tar and it worked great for removing it off the house floors. Walmart, Home Depot, Lowes, etc carry it.
/ old tar removal #5
Soak a towel in kerosene and wipe it down a few times...Let it sit and wipe and wash...Done it many times.
/ old tar removal #6
I agree.....kerosene will work......so will gasoline.....just don't smoke while cleaning the trailer. Good luck!.
/ old tar removal #8
Ditto the WD40.
/ old tar removal #9
Mosquito repellant will take off paint and dissolve most plastics also, so be careful using that. Diesel on a rag will get it off and wont harm plastic or paint finish. Any petroleum product will work to remove tar, just depends on how flammable you want to be, diesel is about the safest for flammability but it will soak into wood and likely carry the tar stain into the wood also as it dissolves it, but it is safe on plastic and can be washed off with some household detergent afterward to remove the oily residue.
/ old tar removal #10
Orange oil, smells good too.
/ old tar removal #11
WD 40 is the best. I am in tar every day and other than diesel this is the best at dissolving and removing tar be it CRS or RC - 250 but diesel smells and stains
/ old tar removal #12
My neighbor runs a chip sealing company and they use citrus bases cleaners such as orange oil.
/ old tar removal #14
Be careful with brakekleen brand brake cleaner. I often use my truck tailgate as a workbench in the field and a heavy spraydown of a greasy part sitting on tailgate has wrinkled and removed paint in several spots.
/ old tar removal #15
That's true for brake cleaner...One quick hit and no more...Works good for getting grease out of carpet though.
/ old tar removal #16
I had thought about trying it on carpet but was afraid it would melt it, so i just took the heat from the wife about the grease. New carpet now. Have some scraps from it upstairs. I will try it on the scraps first the next time i get grease on the carpet.
/ old tar removal #17
Used it for a couple of years while I was a lot lizard at a car dealer in college...the smell is the only problem, it goes away fairly quick if you air out the vehicle...Spray and dab, don't smear.
/ old tar removal #18
Lot lizard means something else around these parts.
Chris
/ old tar removal #19
Lol. Yeah i thought the same thing from my truck driving days but i knew what he meant. His advice just may keep me out of trouble next time i wear grease into the house on my boots.
/ old tar removal #20
ditto that...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
86 (A63290)
86 (A63290)
2015 WINSTON AP22024-DC 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2017 Volvo VNL T/A...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
