power drain on dodge.. got a fuse / circuit question
/ power drain on dodge.. got a fuse / circuit question #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
patient is a 98 dodge ram 1500 5.9l gasser, oe towing package.. and a um.. hoppy brake controller.
truck just started this issue 2 weeks ago. If you drive it daily.. it's fine. if you let it set 3 days without driving it, it drains down the battery so that it may or may not start.
unfortunately.. for now i'm the mechanic at work. ;)
ok.. with ammeter in line.. it did have a few amps of draw.
here's what I have gone thru.
1st, most of the draw was the glove box light. the plastic tab holding the switch broke, so the light was staying on full time. 194 or 168 bulb.
pulled that. kept watching ammeter. I told the driver that the radio will obviously have some memory power.. so for the heck of it.. we pulled that fuse to eliminate it from the draw onthe meter just to see what else might be in the system.
I pulled the alt and it was contribuiting nothing ( good ).. same with the wires going down to the starter / solenoid. ( nothing ).
still had about a 380-400ma draw.
went down the external fuse box under the hood pulling fuses and relay 1 at a time to find the difference.
PS.. with all fuses but ecm pulled there is a paltry 80-100ma or so draw.. not a big issue. figure there are some electronics that just draw quiescent power no matter what.
so i was looking for a 250-300 ma draw.
found 1 fuse that was all of it save the basic 80-100 from t he ecm.
was a 40a fuse. one of then square ones looks like a circuit breaker.. but is a fuse i guess.. marked simply trailer power inthe box, it is the fuse that is right under (empty) diesel pre heat ) slot near the top of the fuse box.
pulling it kills the draw. now.. there are 2 other items dealing with the trailer. there is a relay for the trailer and ANOTHEr fuse marked for trailer under there.
i had to leave after pulling it.. and didn't think to jump in the cab and hit the brake and see if the hoppy brake controller came on.
that hoppy is using the factory molde d plug that plugs in under the dahsh..e tc. it's not a scab on at the brake line and tapped out of the fuse box or anything.
anyone know what all that 40a fuse ( circuit breaker? ) is powering?
ps.. tere was no trailer hooked up at the time of the check.
for now we pulled the fuse and popped it into the dead slot above it for the diesel preheat so the driver don't loose it. if they need to pull a trialer they can pop it right back in. it's good for couple days.. so just plugging it in to pull a trialer is no issue.
if that is it.. my guess is that the brake controller has become marginal, and is drawing near 1/3 amp just setting there looking for the brake pedal to be pushed.
any other guesses with the data provided?
ps.. alt charges fine.. bat is new-ish.. so it is coming back to proper volts after we found her dead a couple times.
we will check again after letting it set from friday to monday and test the hypothesis.
if that is it.. we will put the fuse back in.. and pull the 4 pin on the back of the hoppy controller and see if that prevebts the power drain. if so.. we can toss in another controller. or simply leave it installed and put an inline switch with it for power so it's flipped on when a trailer is needed.
/ power drain on dodge.. got a fuse / circuit question #2
I think you may have already found the problem. If the glove box light is illuminated for 3 days, it's gonna drain the battery. Personally, I'd stop there and see how it goes.
yep.. the glove box light was most of it. I just started thinking about what lamps are on with doors open.. then thought about glove box. sure enough.. switch was broke and dangling and light burning full time. :(
will see.
/ power drain on dodge.. got a fuse / circuit question #4
According to one of the Ram forums I just saw, Fuse F/L #8 ( trailer) powers trailer running light circuit only. I have had several key off drains with my old LHS and they are a pain. You did everything right on diagnostics. I too think the real issue will have be the glove box light.
that's what i'm thinking.
even on a 98 truck.. these things have sooooo much electronics in them.. hard to tell what might be using a few ma here and there.
the glove box lamp was for sure MOST of the draw. the rest of the draw i'm guessing is the various computers and keyless entry unit.. and the security system.
will see if she is low after the weekend.
thanks
/ power drain on dodge.. got a fuse / circuit question #6
I would check for corrosion in the 7 pin trailer connector at the rear. A common problem.
/ power drain on dodge.. got a fuse / circuit question #7
I wonder if they have the trailer power, charging the breakaway switch battery..?? They had our dumptrucks wired that way. Removing the b-away battery + terminal wire should tell you pretty quick.
Just a thought...
/ power drain on dodge.. got a fuse / circuit question #8
That was my thought... I might try pulling the "jumper" harness that goes from the harness that it mounted to the frame (near/behind the rear axle) to the trailer plug and see if that fixes it. Easier than trying to tear into a funky 7 pole plug...
Aaron Z
Aaron Z
will check that.
originally it was the 7 pin plug. somewhere along the way it was changed to a 6.. and is now back to a 7 :)
will check it. it was repalced within 18m or so.. but you never know.
Just a thought...
i know some of our trailers are wired like that. however in this case it was not hooked to a trailer when it died.
however as others said. I will be checking the 7 pin and the jumpe rharness for any corrosion that might be letting power find ground thru that nasty green stuff.
thanks for the ideas guys.
lookign at everything.. not ignoring even the smallest comments.
will let you know what monday shows. :)
and the weekend report.
no dead battery.
it's whatever is on that 40a fuse. and brake circuit that is doing it.
pulling that and the bat don't go low.
can only assume the brake controller is just getting a lil power hungry in it's old age.
/ power drain on dodge.. got a fuse / circuit question #13
Did you ever try it with the 40a fuse in BUT with the glovebox light fixed? Otherwise, how do you know it wasn't the glovebox issue that fixed the problem??
Also, when checking amps inline, did you wait a few minutes after hooking up to let the ecm/pcm power up and then go idle. Any reading within the first minute or so is a false reading.
One more thing, did you unhook the hood light? The power draw should be closer to 50mA, 100 is pushing the upper limits.
yes, unhooked hood lamp.. and did wait for the timer on the ecm / pcm
no, i don't think he tried it with the fuse in.. .. as we removed the fuse and pulled the glove switch at the same time.
good idea.
iDrive TDS-2010H...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
