jim_wilson
- Joined
- Jun 13, 2004
- Messages
- 1,794
- Location
- Northeast MA
- Tractor
- Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I know what you are saying, my B3300 is the same. However, I"m not sure there is a difference between "Out" and "Return". I think the "out" of the BH has full pressure fitting because it runs the 3pt. To me, that just means that when the new valve "out" is T'd into the existing "out", full pressure fittings need to be used.
I could be way off, it does seem a bit too simple.
Here's another diagram that shows a similar setup to what would need to be done to add a grapple to the BH77:
http://www.princehyd.com/Portals/0/products/valves/SVInstS.pdf
see page 2 on the PDF
