Ear Muffs / Hearing Protection while mowing?
/ Ear Muffs / Hearing Protection while mowing? #1
ForumJunkie
Member
NY
Toro Timecutter
Is this a good idea? I think it's time I wear this while mowing for hours at a time. Ebay? Can anyone suggest a basic value priced ear protection headphones?
/ Ear Muffs / Hearing Protection while mowing? #2
Peltor 3MTek have a wire frame and are comfortable- I use them all the time mowing cutting wood, or ear plugs when its really hot.
/ Ear Muffs / Hearing Protection while mowing? #3
I started wearing hearing protection while using a 5hp push mower 26 years ago. I found I was less fatigued after the job. Today, even on the tractor bush hogging, I'll wear ear plugs.
/ Ear Muffs / Hearing Protection while mowing? #4
I buy a few pairs of the better earmuffs at Harbor freight so I can throw them on anyone running my chipper or woodsplitter or weedwhackers, leaf blowers chainsaws..... and the list goes on
/ Ear Muffs / Hearing Protection while mowing? #5
While it is a good idea for hearing protection, I don't wear anything which is probably why I am nearly deaf. I don't usually mow for "hours" maybe 2 at the most and my JD mower is pretty quiet. If I were at it 8-10 hours per day, I would surely break out my shooting ear muffs. Anyone ever do a decibel measurement of their equipment. I know I don't need anything in my cab tractor but would be curious if any actual measurement has been done for different tractors doing different chores.
/ Ear Muffs / Hearing Protection while mowing? #6
Worktunes headphones are great, they have a digital tuner AM/FM with a aux plug for MP3 input.
I think I got mine at Lowes.
/ Ear Muffs / Hearing Protection while mowing? #7
If you are like most folks that use ear buds and headphone, they put the music up louder than what they would be hearing without any hearing protection. Folks that pour on the loud music 12+ hours per day without giving their ears a rest are destined for hearing problems later in life (some of them sooner due to the 100 Db blasting tunes they run about with all day long. I have 80% hearing loss in both my ears and if I can hear the music from a persons ear buds or head phone while setting across an isle from them then it is definitely tooo loud.
/ Ear Muffs / Hearing Protection while mowing? #9
/ Ear Muffs / Hearing Protection while mowing? #10
I wish I had worn something all those years growing up on the farm. Now I don't start a mower, saw or trimmer without my shooting muffs on. Haven't used them on the tractor yet but it's fairly quiet and don't think I've run it more than 20min at a time so far.
/ Ear Muffs / Hearing Protection while mowing? #11
Never wore ear protection when growing up and operating equipment. Wish I had. Always had ear protection when shooting. Hearing protection was mandatory on Helicopters and around other aircraft. I use it when Chainsawing and weedeating. I also use full head and face protection when falling trees. Protection is worn when brush hogging.
/ Ear Muffs / Hearing Protection while mowing? #12
I want to preserve the hearing I have left. You don't miss your hearing until it's gone. I use ear protection whenever I'm doing anything noisy (mowing, tractoring, chainsawing, shooting, etc.) I usually use earplugs because ear muffs are too hot most of the time. I like the ear muff radios, but they are too hot most of the time and where I live the reception is not good.
I'm almost deaf in my left ear and my hearing is not too good in my right ear either.
/ Ear Muffs / Hearing Protection while mowing? #13
I use foam ear plugs. Roll them up and they expand in your ear. I use the kind connected by a plastic string and leave a pair hanging on the steering wheel of the tractor, mower, on the snowblower, tiller, etc. I bought a box of several dozen a few years ago for $20 & they'll probably last me another decade.
Ear muffs are hot and don't fit my fat head too well ;-) I'll have to quit being so cheap and buy a quality good fitting pair sometime. But I still use muffs when making a cut or a few on the table saw or circ saw, etc.
I've had way too much safety training over the years not use something. And hopefully it'll pay off if I ever have some grandkids!
/ Ear Muffs / Hearing Protection while mowing? #14
I also use the bulk corded foam ear plugs. I have a box above the work bench and several pairs thrown in the truck, tractor, chain saw case, ect.
/ Ear Muffs / Hearing Protection while mowing? #15
The cheap muffs I bought are too tight and make my head hurt. I used to use them when my hard of hearing wife had the TV turned up too loud.
/ Ear Muffs / Hearing Protection while mowing? #16
I started out using muffs, but switched to disposable foam ear plugs, as wyeguy and DT86 mentioned. The foam plugs are easy to carry around in my pocket, and I keep some in the glove box of my vehicles and tool box on my tractor so I always have them available, which encourages me to use them.
I use these (32db noise reduction, about as high at it gets):
Laser Lite Earplugs Corded, 100 Pair -GEMPLER'S
I buy the corded version because that makes it easy to remove them from my ears, although the cord sometimes gets in the way when I'm trying to fill a fuel tank. The cord seems to hang right in my line of vision, so I usually chew on it when I'm refueling.
At first they may be hard to use, but after some experience, you can insert them pretty easily with one hand, and you will feel more comfortable having them in when you are running a noisy machine. It's kind of like how you get used to wearing a seat belt in your car, and feel uncomfortable if you don't have it on.
I also try to follow my "no exception" rule, where I always use them, even if I'm only going to be mowing for a few minutes (which often turns out to be longer than that).
/ Ear Muffs / Hearing Protection while mowing? #17
I never used to use any sort of hearing protection, and I felt like a little bit less of a man when I finally started wearing it for everything. I'm sure glad I did, and I wish I had years ago. I use the disposable foam ear plugs w/o the cord. I also leave some in the truck, in the shop, and keep some in the tractor. Hearing loss is cumulative, so every little bit helps. The over the ear style are just too bulky and hot to wear for an extended period of time in my opinion.
/ Ear Muffs / Hearing Protection while mowing? #18
These are my favorites. Inexpensive headband earplugs. (About $6.50 from Bunnings in Australia). I have 4 pair around the place so they are always ready at hand. These are really comfortable. I often forget I'm wearing them. Really easy to slip on and off. No problem to wear with glasses. And they can hang comfortably around the neck without a problem when you aren't actually 'wearing' them. Vastly superior to the little foam earplugs in my opinion.
/ Ear Muffs / Hearing Protection while mowing? #19
I'll repeat here a post I put in the Harbor Freight thread a few months ago:
I just now read the product manuals for HF's various hearing protectors. The $2 red ear muffs give only 2 db reduction @ 125 hz while their foam earplugs are 38 db reduction @ 125 hz. (All the strings on a bass guitar are below 125 hz for comparison.)
What I read confirmed my experience of these products, that the $2 muffs weren't adequate to prevent fatigue from my clanky 24 hp 2 cylinder Yanmar. I've described its sound as 'sledges hammering on a manhole cover'; an overwhelming and tiring pounding if I use the backhoe just above idle all day. (Higher rpm is hardly better just higher frequency).
I looked at some of the other manuals.
The earplugs-on-a-string are only 1 db @ 125 hz.
$6 red ear muffs, the ones some users say have a too-small headband: -5.43 db reduction @ 125 hz. Negative!!! Maybe an echo chamber? But it has good numbers at mid-frequency.
$10 yellow ear muffs: 9.6 db reduction @ 125 hz and excellent numbers at mid-frequency.
After that I bought the yellow ear muffs. I recommend them. They simply eliminate the fatigue caused by hard, pounding sound.
/ Ear Muffs / Hearing Protection while mowing? #20
I use in-ear plugs too, but the tapered soft plastic style with a chord between the inserts. I buy them at Walmart in the shooting section of the Sporting Goods department, three pairs for about $3.
As I am in Florida, sun protection is as important as noise protection. Most of the year I wear a big straw hat when on the tractor and the in-ear style does not interfere with a hat.
CASE 721E WHEEL LOADER (A67714)
CASE 721E WHEEL...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
