Loader Drilling a hole or 2 in the loader: a good idea or not?
   / Drilling a hole or 2 in the loader: a good idea or not? #21
I drilled my bucket shortly after I bought the tractor and FEL used. I bolt 4 x 4's to it all the time for light loads. I've used them to help remove the cap on my truck. I've used them to lift small hay bales 6 or 8 at a time into the hay loft of our small barn. I used them to help haul brush to the burn pile. BTW, the main reason I chose that option is because I'm cheap :)
Well I did it. I visited local welding & steel shop and bought 2 5ft pieces 4" C channel. This will provide a little over 45" of fork length beyond the end the bucket. I drilled 2holes in the bottom of bucket that lined up with factory holes in the front. I got them bolted on and ventured into the backyard. I can't see the front of the forks so getting them lines up is a challenge. I'll post more info as I get some more time to work with them.
   / Drilling a hole or 2 in the loader: a good idea or not? #24
I drilled two holes on the Bucket when I bolted on my W.R.Long Tooth Bar. I also drilled holes when I bolted on three sets of Hooks on the top of the Bucket. When I installed the Hooks, I reinforced the top of the Bucket with a piece of 1/4 inch angle iron. I painted all the hooks and angle iron.
Painting is going to have to be the next step when I get some time and calm day.
I was also thinking that I could re-visit the welding shop, obtain 2 more pieces of C channel, but buy shorter pieces this time. If they only extended out about 10 inches, I could bolt a 2x12 across the front and provide a man-lift for some painting work and gutter clean out.
One of the replies to this post warned of bending / breaking things. I think I could add some reinforcement like you did and maybe wrap the bucket in a chain with a 'boomer' -- a rachet to apply some tension in the middle. This might keep a load from bending the front lip.
I went back to the shop, bought 2 more pieces of C channel, 38" long. 16inches are underneath the bucket, 22 inches will stick out front. This will provide a place to bolt down 2 2x12" 'walk boards' which might come in handy as a platform. Now I just need a volunteer to try it out (and some nice weather -- been raining all day).
   / Drilling a hole or 2 in the loader: a good idea or not? #27
Drilled factory holes in bucket are meant for a bolt on double sided steel edge that is reversible, so it wears instead of the factory bucket edge. I have one on my DK-40, from my Kioti dealer.
KK, the link shows, top of page, 'supplies to N.A.' That covers us US guys.:)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2003 Big Tex 10PI...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
