Remote, battery-powered watering
   / Remote, battery-powered watering #1
econometrics
East Texas
Deere 5075E MFWD OOS w/PR, 540E; Gator 825i
Howdy all,
I have a 65 gallon spray tank that I have elevated about 3' off the ground to water a small garden on some land that has no power or running water right now. I only have 8 plants to water, and have an irrigation system set up.
The problem I am running into is that I cannot find a batter-powered valve/timer that works under low pressure.
How much PSI do you think I am getting from 65gal elevated 3 feet? The first timer I tried just did not flow: Amazon.com: Orbit 62001 Lawn and Garden Digital Watering Timer: Patio, Lawn & Garden
So now I am looking at this guy, which specs at 10-140psi for flow. It has a 5.2gpm flow at 30psi. DIG: 9001EZ-C Battery Powered Hose End Irrigation Timer
Any thoughts would be greatly appreciated!
Thanks!
   / Remote, battery-powered watering #2
Howdy all,
Thanks!
Water weighs .43# per ft of depth. At 3' the pressure is in the order of 1.25# plus any added pressure from the depth of the holding tank.
Yikes, thanks for helping me figure the pressure here. Bottom line, I need a lot more depth or more height it seems.
   / Remote, battery-powered watering #4
If spray tank holds air, you might be able to pressurize it enough to get your valve to work. Even if it blows, the only casualty will be the corn. I assume you have to come back fairly often to add water, so you can pump it back up.
Other option would be an electrical timer and put a small solar panel out there to run it. At some point you're paying about $20 each for carrots, you could buy certified organic grown by monks in Tibet for that price.
   / Remote, battery-powered watering #5
If he's only watering 8 plants they probably aren't carrots :)
OP - have you thought about a drip irrigation? A small drip irrigation with a low flow constant drip might do as well as a bigger flow on a timer.
You could have one or several small drip lines to each plant.
About 120 drops of water = 5 milliliter, so 90840 Drops in 1 Gallon. How many drops of water in one gallon
So do the math.
   / Remote, battery-powered watering #6
I have a similar situation on my block. I use a 23000ltr tank to water my garden. As the head is so low, I cannot use the normal valves.
I bought some stand alone battery timers designed to connect direct to the tap and run from a battery. They do not need pressure to operate as they have a motorised valve. I then have a trickle feed to the garden.
Weedpharma
Weedpharma
From the research I have been doing, this seems to be the route I am going to need to go. Thanks for the input from your experience!
newbury, I did think about the drip route, yes. That was going to be my "fall back" plan if I couldn't come up with anything else.
The garden is nothing too wild - a couple of pumpkins, squash, and tomatoes. We're mostly doing this as a "test plot" on some new land we purchased to see how things take. So, yeah, we're going to put a lot more $$$ into these plants than they are worth, but it's all about getting that experience - which is priceless - right? :laughing:
   / Remote, battery-powered watering #8
I just bought a 12 volt programmable timer and 12 volt, 1/2" gravity feed solenoid valve on Ebay in order to do the same thing you are. I plan on using a small battery with solar charger to operate the valve.
1 2" Gravity Feed Electric Solenoid Valve DDB CD 12VDC | eBay Valve
DC 12V LCD Digital Power Programmable Timer Switch Time Relay 16A US Shipping | eBay Timer
Jim
Jim, that is perfect! This is what I was looking to do, but didn't know where to start. Thank you!
How big is your tank, and how far are you watering?
   / Remote, battery-powered watering #10
It sounds like we have similar scenarios. I started a separate thread last week with my thoughts if you're interested. I'm totally in favor of drip irrigation and have used them in the past. I like the idea of the solenoid and timer suggested and will probably use the same. My biggest concern is how to fill my tank. How were/are you filling a tank that's elevated? Do you just fill it remotely and then lift it up? I'm planning on using a larger IBC tank (300 gallons), and I'm trying to decide how I want to fill it without power from a nearby pond that's 160 feet away. My default is to use a gas powered pump, but I'm seriously considering a wind pump.
LOT LOCATIONS (A51219)
Napa 85-7000 Battery Charger (A48083)
Napa 85-7000...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
