Top Link 'Bracket' Loose Studs
/ Top Link 'Bracket' Loose Studs #1
wingbone
Kershaw, SC
Kioti DK45SE
I noticed the other day I had a couple of loose bolts on the bracket that connects the top link to the tractor(DK45SE). It is the one that has three holes as an option to connect to. The problem is, there are two studs on the lower side that are loose. They are not standard bolts, they are like studs that have slots in them to accept a large screwdriver and then nuts that look like they are used to tighten them up. Is there a specific way to tighten these, as in do they need to be set at a certain depth. I guess you'd have to hold the stud with a screwdriver and then tighten the nut against bracket? I don't even know what they are for and didn't have much time to mess with them the other day after I noticed. I'd just like to have some suggestions before I get back over to my land where the tractor is kept. Thanks.
/ Top Link 'Bracket' Loose Studs #2
I've never checked that area. Will do so this weekend if you don't get a response before.
If you still have your regular small owner's manual, look at section 6-3 where it displays the three choices you have for holes to put top link in. Just below the bottom hole, you can see the studs I'm talking about with the slotted head. The real concern and why I noticed is because I had two different small drips on the frame of the tractor beneath this bracket.
/ Top Link 'Bracket' Loose Studs #4
I see the diagram in the manual. I've never checked those bolts myself but certainly haven't noticed any issue either. You see 'drips' on the frame beneath the bracket, is it hydraulic fluid? I don't see where those bolts would contact any hydraulic fluid but as the rear remotes are right next to them perhaps that is the source of your drips. If I saw drips there on my tractor I would also think the hydraulic topping lift could be a source.
I will have to take a better look when I get back to the land as I was about to leave the other day when I noticed. The part I'm concerned about is how to tighten them. They seemed to be turning freely by hand the other day and not really threaded into anything.
/ Top Link 'Bracket' Loose Studs #6
Do these have something to do with the draft control?? :confused3:
Just got back from looking at them. The top link bracket looks to attach directly to the tractor at the top, but at the bottom, there seems to be two cylinder looking things between the bracket and frame. These two studs are definitely loose and not threaded into anything. I could not loosen or tighten the nut on these studs, probably due to paint. This is definitely where the drips came from but looks like it only dripped a very small amount at each point where the 'cylinders' mate with the frame. Probably about one drip per side. Not sure if this has anything to do with the draft control.
Any idea if they are even supposed to be tight or how to adjust them?
/ Top Link 'Bracket' Loose Studs #11
I will take a look at mine tomorrow. The cylinders you are referring to are the load sensing part of the draught control.
/ Top Link 'Bracket' Loose Studs #12
I just took a look at mine, the slotted studs you refer to look to be where the draft cylinders attach to the top link plate, it should be normal for those to free spin. There are backup nuts on each stud.
Thanks for looking and that makes me feel a lot better.
/ Top Link 'Bracket' Loose Studs #15
Checked mine. They are tight.
If the backup nuts are loose, the shaft of cylinder will turn, to tighten, need to hold screwdriver in slot and tighten backup nuts, at least thats what I'm seeing.
I was going to try that but the paint has the studs and the back up nuts bonded together. Had planned on doing it when I got time but wasn't really sure where to adjust them to even after I got them to unstick from each other.
/ Top Link 'Bracket' Loose Studs #17
If they are stuck together tightening them that way will return them to original position, it may be a blessing they are stuck together then.
They won't tighten. I can move them back and forth as they sit now. They aren't threading into anything.
/ Top Link 'Bracket' Loose Studs #19
Mine are working fine, I can put a wrench on backup nuts and turn easily, If you aren't having any issues with the draft control, I would venture to say you are golden.
/ Top Link 'Bracket' Loose Studs #20
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
2000 Hino (A64194)
2000 Hino (A64194)
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
2017 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2017 BOBCAT MT85...
MF GC2300 fel replaced
