Robin Subaru Engine ID
/ Robin Subaru Engine ID #1
Frank Sorbello
Gold Member
Power Trac PT-422
I need to order rocker cover gaskets for my 1999 pt 422. On Robin's website there is an old type and a new type 22hp engine. How do you determine which engine type you have through the serial number?
My serial number is 4531 1003376.
Thanks
Frank
/ Robin Subaru Engine ID #3
Thanks
Frank
You need the Production number for you engine, located just above the serial number. For example for my PT-425 it is EH720DS00117112.
Then go to the Robin Parts Catalog (ordered by Specification, that is, the Production number):
https://euc.robin-fhi.co.jp/parts_catalog/model.aspx?lang=e
Look up the 1st 5 digits of your PN to get a list of productions for your engine.
You can also Google the PN leaving out the last 4 digits. I found a site that has better prices than Jack's on several parts:
Subaru / Robin EH720DS0011 Parts List and Diagram : eReplacementParts.com
Hi, I bought new valve cover gaskets from Jacks Small Engines. Cleaned the old surfaces and replaced. I still have one side that is dripping oil after running for several minutes. So after running the tractor for a while there is quite a bit of oil in the tub. Would it hurt to double up the gasket?
/ Robin Subaru Engine ID #5
Dear Frank,
It isn't generally recommended to double gaskets, as you are introducing a third potential leak area, and an area that may be more prone to leakage than the existing areas. You also are changing the load on the screws holding the cover on, etc.
Is there some reason to think that the gasket wouldn't have seated correctly? e.g. a dented cover? If there is some reason, you may be better off making a gasket with gasket compound and letting it set.
Are you sure that the leak is coming from the valve cover seal, and not somewhere else? e.g. a cracked cover or a pin hole leak in the cover, or somewhere else entirely?
All the best,
Peter
I doubled up the gasket on the side that is leaking. It is still leaking. I am afraid if I tighten too much I might crack something.
I also noticed when driving today it didn't have much power. I pulled the left plug while running and it shut right down. Started back up and this time pulled the right plug wire and it kept running. I guess I have a problem with the one cylinder.
/ Robin Subaru Engine ID #7
Dear Frank,
Sorry to hear about the problem, but the good news is that you are narrowing it down. Have you replaced the spark plug on that side yet? It is an inexpensive thing to try. Otherwise, I am afraid you are looking at something a little more major, like a cross threaded spark plug seat, or a loose, or cracked head.
Please keep us posted.
All the best,
Peter
JOHN DEERE 5103 TRACTOR (A64278)
JOHN DEERE 5103...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
96in Forks (A64553)
96in Forks (A64553)
2014 Ford Expedition SUV (A64557)
2014 Ford...
213078 (A64276)
213078 (A64276)
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
