P7010 turned into P7030
/ P7010 turned into P7030 #1
Deerherd
Upstate, NY
LS P7030 CPS, 2016 Bobcat E42, Ferris IS3100z w/37 HP Kawasaki
While waiting for the dealer to repaint the loader on the P7010 I was going to purchase, a P7030 with power shuttle came in. After driving it, I went with the P7030.
They dropped it off today.
/ P7010 turned into P7030 #3
Nice!! Can I come over and play? ;-)
Look, your ground appears to be almost dry!!
/ P7010 turned into P7030 #4
Nice. :thumbsup: :thumbsup: Hey, did you trade the Kioti in, or private sell it? These bigger tractors sure are nice, aren't they? :cool:
Traded it in and yes, a big tractor sure is nice! Top n Tilt is on and when they installed it the guys in the service department didn't see the box you sent with hoses and fittings and made some up. It looks like they used a smaller diameter hose. I will take a picture when it gets light and post it. They said I could have the hoses you made and was wondering if I should use the ones you made up versus the ones they did. It seems to function correctly.
And the ground being dry is an illusion. I took that photo after dropping off the new Athens disc in the field and was praying I didn't bury the tractor the first hour I had it!
I'm pretty excited.....
/ P7010 turned into P7030 #7
You should be excited .. thats really nice.
/ P7010 turned into P7030 #8
When I bought my 7010 the dealer tried to sell me a 7030 that he had received from another dealer that couldn't sell it. He made me a real good price on it too. I just didn't need the extra HP. Heck I was looking for a 50 HP when I got the 7010. I maybe should have looked at it to see if it had the power shuttle as that would have been worth the extra money.
/ P7010 turned into P7030 #9
I doubt that the dealer installed flow restrictors as that they are in with the hose kits. The flow restrictors make operating the "TnT" much easier. They might have used 1/4" hose which is fine, but I would definitely use the flow restrictors.
I'll check it out, thanks Brian
I didn't really need 88 HP or 40 forward speeds either but the power shuttle is sweet! I took the fel off and here some more shots.
/ P7010 turned into P7030 #13
Man that is a sweet tractor. Wouldn't fit in the garage though and I am not building a new one! Heck I might not even have enough room to turn it around!:shocked:
Nice tractor!! How big is that disc harrow?
It's a little more than 8 feet wide and around 1800 lbs. I wanted to be able to transport it down the road with a pickup without drawing too much attention.
As far as turning radius I was pleasantly surprised how well it does, especially with the fel off. I can spin it around in the drive no problem. I'm a happy guy.
I have set off the transmission "cutoff alarm" a few times, it's a good reminder to NOT ride the clutch with the power shuttle. It's taken a little getting used to when hitching up an implement, especially on an incline. Of course there was nothing in the manual about it and the first time it happened it was quite a start, the alarm is REALLY loud!
/ P7010 turned into P7030 #17
Could someone explain the power shuttle, as opposed to the regular shuttle shift? I couldn't find an explanation at the LS site.
/ P7010 turned into P7030 #18
Good question!:thumbsup:
/ P7010 turned into P7030 #19
I know you want to toe that disc down the road, but isn't that tractor rated for a much much larger disc?
/ P7010 turned into P7030 #20
With a regular shuttle you have to use the clutch to change from forward to reverse and come to a stop. With a power shuttle you do not, you can just step on the brake without using the clutch and move the forward reverse lever. I believe that you need to use the clutch to change gears though. Hopefully someone with a power shuttle will chime in and confirm this. ;)
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
Rogator RG1300C (A63689)
Rogator RG1300C...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
