montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #1
fredshop2
juneau alaska
case
I would like to know the spec s of the pump and if any ones knows where to pick up a replacement
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #2
Welcome to TBN
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #3
Welcome to TractorByNet :tractor:
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #5
Are you looking for parts?
Do you want to replace that pump with something equal?
What is the HP of the engine driving the pump?
Can you show a picture?
Would you need a two stage log splitter pump to match your engine?
the engine is a 8 hp briggs and stratton I wanted to find a pump comparable I sent the pump no. some body out there may know the spec.s then i can try and locate a pump out there . any heelp would be apreciated skip
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #8
John S. Barnes was purchased by the Haldex corporation several years ago and now recently someone purchased them from Haldex so I suspect information on that pump may be hard to get.
I would check the front mounting features and drive shaft size and then find a pump like J_J references with these same features.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #9
If the pump above will not fit your pump mount, then select a pump mount from this list, observing the bolt hole pattern.
Most 8 HP engines are 1 in shaft.
You might need to change out the couplings. Lovejoy type, etc.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #10
oldnslo, Is John S Barnes on the river my state st, or is that W.F. & John Barnes?
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
Schumacher Jump Box (A54865)
Schumacher Jump...
2006 FORD F-350 (A53422)
2006 FORD F-350...
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
