Leak in the middle
/ Leak in the middle #1
GMtb42
Gold Member
Spiro, Oklahoma
SOLD Kioti CK20 HST Purchased CK3510SE HST
I noticed the other day a drop of oil on the ground under the tractor, got to looking and saw a couple of more beads of oil coming from a inspection hole in the mid section (section between the motor and rear-end) of the tractor, anyone have a manual and can tell me what it might be leaking in there, can't get a good line of sight to inspect the area. Would be much obliged for the info. 2004 CK20HST
Thanks in advance.
Looks and smells like Hydro fluid not motor oil.
/ Leak in the middle #4
Check the test ports on the top and the side of the HST. I believe there are 5 or 6 ports for testing pressures. The ports have a Allen head on them and if they back out the o ring will blow out causing a leak that looks like the main seal on the hst. Hope this helps as it is an easy fix.
Will try and find tomorrow.
I think I found what you are describing, there are 5 plugs, 3 on top in a row and one on either side, they are tight, so main seal? If so what does that entail?
/ Leak in the middle #7
I had this problem on my CK30 and I've read a bunch of people with similar issues. Do a search, I know I've read a couple other threads either in the Kioti forum or the Bobcat forum, maybe somebody answered it. I'm not sure what the cause was on mine, I traded my tractor before my dealer fixed it, but it started with less than 100 hrs.
Got to looking further and saw 2 more plugs under the tractor, those were tight too. Darn!
Okay thanks.
I found this thread after a long search : http://www.tractorbynet.com/forums/kioti-owning-operating/244056-small-hydro-leak-issue.html is this the one you are referring to?
Says o-ring leaking -- tractor split to replace.
/ Leak in the middle #12
That's not good news, mine has been dripping for a little while now and I only have 95 hours on the clock, probably around 60 when I first noticed it.
Mine is due for some warrantee work anyway, so I better send some pictures to my deal and make arrangements to get it fixed before the ground dries out and I need the tractor again.
Jason
Yup thats the one.
Okay at least I know what to expect, doesn't look that hard to split at that point, a few bolts. Guess a manual/parts are in order and the time needed to do it then.
Glad it is just a o-ring.
Jason
Good idea.
/ Leak in the middle #15
Glad it's something you're up for tackling, it's a little more than I'd be willing to try. Mine didn't start leaking until after they split the tractor to replace the HST. After they had done that, I had them add a cab, so splitting it again was going to be a little more challenging, but I guess they must do it all the time. Anyway, I was sure it was a seal that was damaged or an o-ring that didn't seat properly after the split, but never heard for sure.
/ Leak in the middle #16
It really isn't too bad of a job.
The hardest part for the home mechanic is holding the 2 1/2's up while it is split.
BTI
BTI
Yeah, that is what I was contemplating on, how to hold the 1/2s up. Was thinking of welding up some supports to carry the weight of the halves. Will wait till winter this year I suppose since mowing season is coming up.
/ Leak in the middle #18
Hey there this is Dingo Man who started that thread. My DK40 had a similar hydro leak. If you search my threads I actually posted a couple pics. Mine also leaked down through an access hole in the mid section. I never learned the cause of mine. After splitting the tractor three times Kioti authorized my dealer to install a brand new hydro pump, and it has not leaked since. They theorized the one of the out flow fiitings on the hydro pump was not machined quite right allowing it to leak even after reading o-rings.
My only suggestion is check your power steering lines up under your steering column. This is what they had me check first, and I know it is quite common on Kiotis that these lines loosen up and leak. I know the DK and CK are probably apples and oranges but that is my story. Good luck.
Thanks for the reply Dingo Man. :thumbsup:
Yeah saw the picture, exact same spot this one is leaking.
Will post back after I do the o-ring replacement this Winter.
2000 Hino (A64194)
2000 Hino (A64194)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
