JD 2520 sort of sluggish during throttle up
   / JD 2520 sort of sluggish during throttle up #11
Brian
Maybe I overlooked it as I just looked in my operators manual and couldn't find fuel conditioner mentioned. Operators manual did state to keep water & dirt out of fuel. I still think that unless it's required such as for a sticky injector, fuel conditioner cost exceeds it's benefits for every day use. As has been previously stated opinions resembles navels as everyone has one.
   / JD 2520 sort of sluggish during throttle up #12
Brian
Everyone is entitled to run and treat their equipment how they see fit. The fuel treatment I run costs me about $40 or so every 2,000 gallons, I probably will never run 2,000 gallons through my tractor. I look at it as preventive care. Waiting to treat something after it shows symptoms is usually too late and the damage is done.
There are other reasons for treating the fuel too as well, not just because of the equipment. If you have bulk storage, lets say 500 gallons, and you only burn 10 gallons a week, the fuel treatment will help preserve the fuel and keep it from being contaminated (to a degree, obviously if you pour in dirt you're screwed). Filters and water separators can only do so much.
As for trusting your "John Deere" operators manual, when they produce one that is nearly error free (and not just typos), maybe I would trust mine. I also believe that JD as well as other manufactures are in business for parts and not necessarily sales of new equipment. Of course that is just my navel speaking. LOL
   / JD 2520 sort of sluggish during throttle up #13
First dyno diesel doesn't deteriorate similar to gasoline so what can a fuel conditioner do to prolong diesel's life except help disperse water? Second I never stated JD operators manual as it was a Kubota OM that I looked in to find "no fuel conditioner" mentioned. You must have a good source for fuel treatment because Power Service brand fuel treatment cost $19.95 for 80 oz and that treats only 250 gallons of fuel. Now that's my navel.
   / JD 2520 sort of sluggish during throttle up #14
My operating manual says to use an additive if " Cetane and lubricity properties of the fuel are low or unknown", which is always:laughing: Microbial growth is also a concern for storage.
   / JD 2520 sort of sluggish during throttle up #15
Microbial growth is caused by water in diesel therefore if there's no water there's no microbial growth. On the matter of lubricity I was told by my fuel supplier that lubrication was added at the refinery. I have not stated not to add fuel conditioner to diesel fuel I just think the benefit of adding conditioner to every gallon isn't worth the cost IE not cost effective.
   / JD 2520 sort of sluggish during throttle up #16
Jim, hopefully I am not coming off rude, cause that is not my intention. I was basing my "owner's manual" comments off the JD manual I have and what I have read about other JD manuals. Mine doesn't even bother to tell you that there is a dipstick for the hydraulic fluid for the 2520, nor does it tell you about the nearly impossible to reach u-joint on the front drive shaft of the 2320. I had a Kubota before I went green, and its owner manual was definitely better than JD.
I do have a good source on fuel conditioner among other things (I have a friend that is a distributor/wholesale that I buy from to sell at retail), but I was off about $10, so it is about $50 (retail) per gallon jug that treats 2000 gallons.
As for the lubricity of the fuel, that is going to vary from fuel station to fuel station and the jobber that sells it. I know from personal experience (well not directly my personal experience, but I trust the source) that not all jobbers are honest about what they sell. Most are honest, but there is always that few. I also know the local Kroger's get their fuel deliver by Flying J trucks, but the fuel doesn't come from the same place that the Fjying J and Pilot truck stops get their fuel. I don't buy from dirty fuel stations, it is my opinion that if they don't keep the place clean, then it is probably true about their fuel storage. As for Algae growth, it does take sunlight for it to survive, but there are other microbes that can live in the dark and feed off the fuel and use that little bit of water (there is almost always some water in a tank) that is in your tank for the oxygen it needs to survive.
Is it really necessary to run it? Probably not in most cases. Depending on the area, the fuel may be top notch and maybe that is why you haven't needed to run a fuel treatment (not everyone is going to be that lucky), other areas especially rural, well... I guess that is why I have a 50 gallon tank in my truck, I won't stop at those places. Obviously I recommend it, or I wouldn't be suggesting it as a cheap form of insurance. I have seen what adding a good fuel treatment to a piece of equipment (that has been neglected) will do to fuel filters as it cleans the gunk and varnish from the tank and fuel lines. There are numerous independent studies on the benefits of using a fuel treatment. Fuel treatment is a broad term that can be described in many ways as a cetane improver, detergents to clean your injectors, lubricity, anti-foaming, low temperature operability, fuel stability and so on. The fact that ULSD isn't as stable as its predecessor and tends to break down quicker, but you are right, it is still more stable than gasoline.
   / JD 2520 sort of sluggish during throttle up #17
Aw it's no problem just a difference of opinion. Yes I think there are circumstances when diesel fuel conditioner is required but not every tank full. Do I think fuel economy will increase enough to justify the cost? Not even hardly. Bright side is s long as you put fuel conditiner in your Isuzu hopefully you won't have to replace those high $$$$ injectors. Have a nice day and it's been an enlightening topic. Jim
2019 FREIGHTLINER CASCADIA DAY CAB (A51222)
2019 FREIGHTLINER...
New Holland 1431 Discbine (A50515)
New Holland 1431...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
2019 Dodge Journey SUV (A50324)
2019 Dodge Journey...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
