ford 9n
   / ford 9n #1
Kitz
anywhere usa
IH 244
Simple question maybe Is the ford 9n any good
   / ford 9n #2
Simple answer, yes depends
   / ford 9n #3
Yes it is. If it wasn't why would they have made 100,000 of them.
   / ford 9n #4
I got one.. it's good for what it does! Spread fertilizer and spray weeds. Need to rebuild the 3pt, though. It won't rake or tedd very well at the moment... the attachments are too heavy for that "tired" 3pt. :)
AKfish
   / ford 9n #5
We used to have a 9N when I was a kid. It was a nice tractor for it's size. Ours had some 3pt problems also. I finally rebuilt the lift. I was only about 17 at the time and the first time I had ever done something like this. WOW! that arm assembly was heavy.
Our had leather seals that we had to order from the local tractor place. One thing we did not like with our 9N was that the 3pt did not work unless the PTO was engaged.
Later on, we had trouble getting parts. We had real problems getting the throttle linkage. The last straw was when we needed a new carb ... finding one of those up-draft carbs was next to impossible. The tractor place said they were no longer available since our tractor dated to around 1939. Then, that tractor place moved and later changed brands.
We also had to replace the gas tank and the radiator. We could not get originals of these either so we made a gas tank out of a beer keg and the radiator came from an old Rambler.
I still have shoulder problems from cranking that thing with the hand crank because the started was also toast. We finally replaced it with one that was rebuilt when we converted the tractor to 12V. The starter was still 6V and would really spin that thing!
All-in-all, if you find a good one, they are fine tractors ... if you get one that needs a vast amount of work, be prepared to do ALOT of work.
   / ford 9n #6
and if you count 2N.. which were 9n's in form.. just a way around wartime restrictions.. then that # jumps to over 258000 units by mid 47.
   / ford 9n
what happened to my replies
   / ford 9n #10
not uncommon for all posts past a certain point to go when pruned.
at least one of mine went as well.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2013 John Deere 310SK (A47384)
2013 John Deere...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
