ignition timing Kubota m4050
/ ignition timing Kubota m4050 #1
alfalfajoe
Victoria, Texas
Kubota 4050
Does anyone know how to set up an ignition timing light on a diesel s2600 engine? What kind of timing light connects to the diesel line?
/ ignition timing Kubota m4050 #3
Welcome from Ohio, Yes I am sure Roger can help.
/ ignition timing Kubota m4050 #4
Diesel timing cannot be adjusted using a timing light. There is no spark to adjust, only the injection occurrence itself.
The timing of injection, at least for the type of engine in question, comes from the injection pump.
/ ignition timing Kubota m4050 #5
Welcome to TractorByNet. :tractor:
/ ignition timing Kubota m4050 #6
That is not entirely true. You can clamp a pressure transducer to an injector line that converts the pressure change to an electric signal for the timing light. I have one and it does work, though spill timing is much easier in my opinion.
Brian
/ ignition timing Kubota m4050 #7
Brian
Well, I learned something new just now!
/ ignition timing Kubota m4050 #8
Me too!
/ ignition timing Kubota m4050 #9
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
2021 HUNTER WHEEL BALANCER (A59909)
2021 HUNTER WHEEL...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
2021 John Deere 5230L Applicator (A63109)
2021 John Deere...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
