Need Lug Torque Value
/ Need Lug Torque Value #1
RFB
None
Sirs,
I have a B3000 that I want to check the front and rear wheel lug torque settings. My Op Manual says "tighten the bolts to the following torques..." but then does not provide any. (My 5740 says the same thing and provides the numbers.)
I am kindly asking if anyone has those values (and I would imagine that the B3030 is the same) could you please provide them.
Thank you.
/ Need Lug Torque Value #2
My B7800 is the same tractor, only older. Torque values in the manual are:
Front wheels.....57 to 67 ft.-lbs.
Rear wheels - nuts.....123 to 141 ft.-lbs.
- bolts....145 to 166 ft.-lbs.
Hope this helps.
/ Need Lug Torque Value #3
Sirs,
Thank you.
The end of each of those paragraphs on p.42 of the Operator's Manual reads: (See "MAINTENANCE" section.) Kubota has a slightly different way of getting information across to us. Go to p. 66, Periodic Maintenance. The right hand column is 'Checking Wheel Bolt Torque' and the graphic on the bottom right of that page gives you wheel bolt torque in N-m, kgf-m, & ft-lbs, so you can set your nice torque wrench to whichever reading you like.
Thank you gentlemen.
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
2016 BOBCAT T650 SKID STEER (A62129)
2016 BOBCAT T650...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
