Flat tire
/ Flat tire #2
Depends on the size of the hole but yes for punctures like a nail hole you can patch them. A half inch rod thru the tire would require a boot and & or tube.
/ Flat tire
Most likely a nail hole, have been tearing down an old building. Tire is a 9.5-25 tubeless R1.
/ Flat tire #4
depends.
I have a tire on my 7610s that had something like a RR spike go thru.. you can stick yer finger thru the hole. it has a large 6" farm patch on the inside... and a new tube.. ( was tubed already ).
holding fine.
i HAVE used boots and old split tubes depending on rim and tire casing condition though.. just never know till you see it.. case by case basis. IMHO
I will say this though.. I always put some sort of patch.. even the small bike style patches on holes in tire casings if there is a tube.. otherwise the hole can bit the tube..
/ Flat tire
Tire has 67 hours on it. If I put my finger on the hole I can stop the leak. Can't be bigger then 1/8", if that.
/ Flat tire
Just a regular one from TSC.
MAGNUM LIGHT PLANT (A60736)
MAGNUM LIGHT PLANT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
(INOP) 1997 FORD ECONOLINE VAN (A59823)
(INOP) 1997 FORD...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
Kubota L2502 (A60462)
