Posthole Digger Post hole digger
/ Post hole digger #1
almost13ranch
John Deere 3120
What do you all do with your post hole digger when it's not on your tractor?
/ Post hole digger #2
you bring it to my house i have been wanting one
/ Post hole digger
I was sort of thinking about keeping it, it's growing on me.
/ Post hole digger #4
Put it on a stand.
/ Post hole digger #8
Made a rolling stand.
/ Post hole digger #9
I disassemble it, it just takes a minute to take off the auger and break it down into pieces that I can easily move by myself. The whole thing is probably 200 lbs but no one piece is more than about 60. Then I put the pieces in the corner of my garage.
/ Post hole digger #10
I use a small chain hoist to hang mine over head in my pole barn. Also do the same thing with my 3pt 600lb capacity spreader. Not things I use that frequently so it keeps the up out of the way and protected.
/ Post hole digger #11
I just used my phd to sink a post and then I put a eye bolt at the top of the post with a short chain and use a clip.
/ Post hole digger #12
In my tractor barn I made a swinging arm to sit my phd down in. My digger is the old style with a huge gearbox, probably 100 lb or more. I remove the bolt and drop the auger, stand it in a corner with the others. I then sit the shaft coming out of the gearbox in the piece of pipe cut to fit the bottom shaft on digger gearbox and relax the hydraulics. My digger is assembled with pins. So I pull the pin that drops the gearbox and unhook the PTO shaft and then swing it up against the wall and hang the PTO shaft on the wall using the hook mounted for just that. Remove the pin holding the boom pole to the yoke and the pin holding the other end where the top link normally fits, hang it on the wall. Then remove the yoke from the lower pins. Takes about 5 min to put on or take off of the tractor.
This swing arm I speak of was constructed with a 3" piece of pipe that matches the shaft on the phd, welded to a 2' length of 2x2 tubing with a hinge built from flatbar and a bolt connecting the two sides. I used two ears on the tubing and two identical ones welded to a piece of 3x3 angle-1/4 in thick. I bolted the angle to a post in my barn.
It fits snuggly against the wall, is out of the weather, off of the floor and easily hooked or unhooked in 5 min. Took about 45 min to build including flat black fast drying paint.
/ Post hole digger #13
Like said........ I have mine broken down into 4 parts, and hung on the back wall of the garage.....
I can handle each part individually a lot more easily than the whole unit.
Good luck
/ Post hole digger #14
My Bush Hog post hole digger has the optional stand. I back up to it and slide three pins in. There is no lifting.
/ Post hole digger
D you have a picture you could share?
/ Post hole digger #17
I bore a hole and then leave auger in the hole, set a pair of blocks under the 3pt pins and drive away.
That way I can back up to it and hitch it up without having to lift or move anything.
I can't take credit for this idea - someone posted this idea a few years ago and I just happened to remember it.
/ Post hole digger #18
Just tear it down into 4 components when I take it off the tractor and put it on a pallet to be stored on shelving. It makes putting it on the tractor easy, put the yolk on the 3 pt arms, attach the boom to the top 3 pt pin and the yolk, hang the gearbox/pto on the boom and then install the auger. Makes a nice compact package for storage.
/ Post hole digger #19
almost13, Ill take a few pics and post them tonight. Never posted pics but I think I can do it.
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
x (A68191)
x (A68191)
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2018 FREIGHTLINER...
3 ROLL TOOL CARTS (A68842)
3 ROLL TOOL CARTS...
