Mighty Little Bulldozer
/ Mighty Little Bulldozer #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have some hunting land that needs to be screened off from surrounding hayfield, barn etc. Here is a picture looking from the barn toward the hunting area.
I decided to build a mound, plant some grass on it, and add some downed tree limbs. For the mound I used my tiller to loosen the soil, and then pushed it into a windrow with my mighty little CK30 bulldozer. I have a crick in my neck from looking backwards all day long.
I made a couple of passes at it, and have a mound in the making. Will take some motrin and give it another pass.
/ Mighty Little Bulldozer #6
Need eyes in the back of your head.:laughing:
That would be nice for this job. There were many times that I would not look backwards, but would just judge the strain on the tractor and the spinning tires to know when I needed to raise the box blade.
/ Mighty Little Bulldozer #8
I've read about folks bending their 3 point linkage from too much pushing or hitting stumps and rocks. You, evidently don't have such a problem....and / or are a good operator. Nice work.
The tractor and the box blade seem to be fairly evenly matched. Going a medium steady speed the tractor seems not strong enough to over push the blade. The tires spin before the bars bend, or at least that is what I am hoping.
Over extension of equipment, and even of myself, has always been a fault of mine. I am trying to improve that for myself, and the equipment I use.
/ Mighty Little Bulldozer #11
That's a good question. I box blade in reverse a lot and always assumed (or hoped) I'd run out of traction before anything bent. I understand the links are much stronger in tension, bit I figured they were designed for that.
/ Mighty Little Bulldozer #12
Good job.
With several different tractors and using box blades for serious dozer work we have messed just some three point linkage on the box blade from lifting and pushing at the same time with good traction BUT never hurt any tractor linkage. Unless you rotate the tires from side to side backing up traction is limited.
2019 CATERPILLAR 279D SKID STEER (A65053)
2019 CATERPILLAR...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64278)
2023 JOHN DEERE...
HOMEMADE 14' - 3 REEL TRAILER (A63276)
HOMEMADE 14' - 3...
48in Hydraulic Forks and Frame Skid Steer Attachment (A64553)
48in Hydraulic...
