Winch wiring
/ Winch wiring #1
6839
Warren, MA
John Deere/Mahindra
Newbe here. Looking for suggestions on how to power a winch on a equipment trailer (10k, 18'). Separate battery won't work as the trailer won't be used that often. Direct wiring is a little expensive. Heard a suggestion of splicing booster cables together to go from tow vehicle to winch mounted on trailer. What gauge wire will be needed? Can I ground the winch to the trailer & run one wire to + side of tow vehicle battery. Anything will be helpful.
Semper Fi
/ Winch wiring #2
I use my jumper box. Have for 10 years and it works great.
Short of that you will have to run a heavy gauge wire the entire length of the truck, 4ga or better.
A dedicated battery and cheap solar charger will be the cheapest way in the long run, about $100.
Chris
/ Winch wiring #3
Honestly -- a heavy gauge wire can be expensive to be run all the way to tow vehicle, esp it you gotta use it with your tractor. most on road vehicles is setup anyways with thinner wire to charge the battery to trailer and this is easy and cheap to do on a tractor as well. I really like diamond pilot suggestion too - a portable jumpeer battery to be used in a pinch but also keep a solar trickle charger on all the time.
/ Winch wiring #4
I'm with Diamondpilot. Have done that several times with success as most pulls are short and not extremely heavy load.
/ Winch wiring
Chris
Thanks, for the suggestions. I'd probably won't use the trailer 2-3 times a year, so that's why I was looking for a different set up than a battery. Wouldn't you have to get the jumper box charged up also?
/ Winch wiring
Kind of new at this. I think I just sent a reply to myself. Wouldn't you have to keep the jumper box charged at all times? Isn't there a battery in those? This trailer is for farm use. Getting tired of paying 200-300 when I need to move the tractor. Thanks for the suggestions.
Semper Fi
/ Winch wiring #7
Yes, they have a battery in them. My jumper box sits in the shop for months at a time between uses. It holds charge very well and I only charge it after heavy use. I rarely use my winch too. That's why the jumper works so good.
/ Winch wiring
Thank you. Someone suggested a JNC950 I think it means a jump n carry 950. What do you have/use/recommend I consider?
/ Winch wiring
Anyone heard of a JNC950 from Jumpstarter.com? Tried the website but couldn't pull it up. Saw a Jump-n-carry 950, but not sure it's the same thing.
Semper Fi
/ Winch wiring #10
Yea. I keep two charged up at all times. One at home and on at the shop.
Chris
/ Winch wiring #11
extra battery, just used for winch duty.... kept in the shop on a trickle charger.... or your trolling motor battery.... or your RV battery.... or ......
same idea as a jump box, just larger capacity.
/ Winch wiring #12
That is what I do. I have a few old car battiers I use.
/ Winch wiring #13
If you want to do a run from your main battery, running ground thru the frame works fine.
Used a Anderson powerpole 175 amp connector between truck and trailer.
/ Winch wiring #14
Your choice of connections would depend a bit on how much you wish to use the winch with the trailer.
I added a receiver to the front of my Blazer.
Made with a piece of channel iron, and a receiver tube.
It is more securely connected to my winch than my winch is connected to my bumper or frame.
Anyway, so all I do is insert a drop hitch.
Pull up to the trailer and hook on.
The advantage of the hitch is that I now have control of the trailer.
And I have a great multi-purpose winch.
I haven't used it with a tilt trailer though.
/ Winch wiring #15
i put a bat on the trailer that is charged when hooke dup to the trailer plug. works great for a electric winch.. wireing is easy.. 90% of it is already there.. :)
/ Winch wiring #16
I hooked mine up like Sound Guy. The battery operates a 12,000 winch & the hydraulic pump for the trailer tilt. I have the winch mounted on a 1/4" plate welded to a section of 2" x 1/4" wall square tubing which slides into a standard receiver hitch & have wired it with short lengths of #2 copper wire with welding lead connectors to make placing the winch into operation a snap. The battery on the trailer has matching cables attached. (The positive (+) is a female & the negative (-) is a male to help prevent it from being connected backwards. I also have a heavy set of battery cables which have a pair of the welding connectors on one end to allow me to use the winch anywhere I have a battery available.
Some of the ways I use my winch: Skid logs with tractor, load vehicle on trailer, mounts on boom on loader & can pull up well pumps (The boom reaches 29' in the air), vehicle recovery, stretching fence, ...
/ Winch wiring #17
My warn winch (12000) has always worn the battery jumper box down before getting the load on the trailer. I use a 1000amp top post autozone battery with the harbor freight solar battery charger always hooked up. This is sometimes not enough. Out comes the 24 ft jumper cables to the two batteries under the diesels hood. This is exactly why commercial rigs run PTO or Hyd. winches.
/ Winch wiring #18
2458n - That is Weird! On a full charge, my 1000 CCA battery (has dual terminals) when not hooked up to a charging source will run the hydraulic pump to tilt my trailer, run the 12,000 lb Badland winch from Harbor Freight to load a full sized van, lower the trailer to transport position, Re-tilt & lower at delivery point, run the winch for a controlled unload (though most of the time I just let the vehicle roll), & still have battery to spare. Have you done a load test on your battery to check for a bad cell?
/ Winch wiring #19
Same here. My winch is only 4500# but I have loaded 3 cars in a 2 hour period using my jump box with no sign of slowing down.
Chris
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
JOHN DEERE 317G SKID STEER LOADER ARMS (A64281)
JOHN DEERE 317G...
