60" or 66" box blade for 235
   / 60" or 66" box blade for 235 #1
Skinnyman
Wilmington, NC
Bobcat CT235
Any of you guys with a CT230 or CT235, what size box blade are you using? 66" would completly cover my tracks with GP tires, just want to be sure I have enough tractor.
   / 60" or 66" box blade for 235 #2
Go with a 72in, my 235 handles it just fine with GP tires
   / 60" or 66" box blade for 235 #3
I have a CT230 and have a 72" united BB. I don't seem to have any issues dragging it when the box is full.
Thanks guys, that the info I needed. By the way galaxie, how do you like the United Boxblade? I have a distributor near me.
   / 60" or 66" box blade for 235 #5
I had a 72" box blade on my Ct235, it weighed 450lbs. I would have liked to have had a real heavy 66". Don't get anything less than a 66'', it will be narrower than you tires.
   / 60" or 66" box blade for 235 #6
When it comes to box blades weight is your friend. A heavy 66" would be a great option for you.
   / 60" or 66" box blade for 235 #7
I like it. It is not as heavy as some but I got it for a good price. If I used it all the time, maybe I would have went for something heavier but this one works for me. I thought about adding some weight to it but it has done a good job for me as is.
If you have extra money or plan on using it a lot, a heavier BB and one with hydraulic rippers might be worth the extra money.
   / 60" or 66" box blade for 235 #8
I have a 72" Woods that helped get me through this past winter. It is not too much for the tractor with filled rear tires. I did get slid around some when the snow banks got larger. Next year a snow blower should help level the playing field.
   / 60" or 66" box blade for 235 #9
I have a Land Pride 72 inch on mine. No issues and a good unit.
TORCH SET GAUGES, HAND CART (A52708)
TORCH SET GAUGES...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
JOHN DEERE 3PT HITCH BACKHOE ATTATCHMENT (A58374)
JOHN DEERE 3PT...
Lely Towable Fertilizer Spreader Attachment (A56857)
Lely Towable...
