DIY PTO Generator
/ DIY PTO Generator #1
coldstream
Member
NW MO
I'm considering building my own PTO gen. I can buy a generator head unit and will probably look for a 5KW to 8KW unit. I saw a youtube where a guy built a belt drive set up off of the PTO and that might work. I'd have to come up with a couple of 2 or 3 belt pulleys of the proper diameter to run off of my 540 or 1000 PTO speeds (probably 1000rpm because the needed pulleys would be closer in size). I'd also like to investigate using a PTO gearbox like the one's used on the commercial PTO generator units. Does anyone know of a source for a gearbox (speed increaser, 1000rpm input, 3600rpm output)? I have no idea how much such a box would cost but am curious. I've looked a bunch on-line and am coming up with nothing. Thanks for any input!
/ DIY PTO Generator #4
If I was looking to build a 3ph generator it would be bigger than 5-8 kw. You can buy a ready made 5-8kw generator cheaper than you could build a 3ph one. And have a lot less expensive engine running than your tractor engine that would also operate cheaper, no hrs on your tractor.
/ DIY PTO Generator
Thanks buickanddeere for the ebay tip. I checked those out as well as the generators on the same page. Looks like it would cost me about the same to buy the components or build it myself for this size of generator. I'd still build it myself though so I can get some practice with my new welder and for the satisfaction of completing the project. Oh and I'll definitely make sure that proper guarding is installed on the exposed rotating parts! My Kubota only gets maybe 50 - 60 hours/year put on it so I'm not worried about running that sweet engine a few hours now and then for power generation. And I do not want to own another small engine which requires gas/maintenance/attention. I've already got 15 engines to take care of now between cars/tractors/motorcycles/atv's/chainsaws/weed trimmers/mowers/etc,etc,etc!
/ DIY PTO Generator #6
i'd go gearbox.
add up the $$ may be chaper to get a northern 7k unit already set.
I'd avoid belts.. slippage.. etc.. and if you make it for 1krpm and then sell the tractor and don't get another with a 1k pto.. then where are you at.
/ DIY PTO Generator #7
I've considered building one myself, with the Harbor Freight generator head $299.99, and have subscribed to this thread for ideas. Good luck!
/ DIY PTO Generator #8
I'd do a geared drive again. You can still get some fab time in welding up a frame and base to mount it on. I drove this 12kw off of a 650 JD. It was only good for about 5 or 6kw but now the 3520 will play with 12Kw. PTO gen.jpg
/ DIY PTO Generator #9
was your frame a custom bend up job.. or repurposed from something else like a mower deck shell?
just curious.
looks great by the way. :)
/ DIY PTO Generator #10
I'd do a geared drive again. You can still get some fab time in welding up a frame and base to mount it on. I drove this 12kw off of a 650 JD. It was only good for about 5 or 6kw but now the 3520 will play with 12Kw.View attachment 309402
Where did you source the gearbox and head?
/ DIY PTO Generator #11
lotsa sources for heads.
northern tools.. harbor freight.. etc. ebay has a ton of them.
I've seenthe gearboxes at surplus shop...
/ DIY PTO Generator #12
I bent the H.wall SS pipe and 1/4" plate myself. It came from "electric generators direct.com. "
And thanks. I really enjoyed building it and TIG welding the pipe. The frame is actually in 4 pieces.
/ DIY PTO Generator #13
nice.. :)
/ DIY PTO Generator #14
Too bad your not closer I have a 10 kw head with control box and pulleys I would give away,, Too many other projects going an I'll never get to this one,,
/ DIY PTO Generator #16
This is the belt driven PTO generator I put together. It is a 7kw military Onan. Yes it has open rotating pulleys as did much of the farm equipment I grew up around. It is being powered by a B7100 and ran 16 hours a day for 7 days. No belt slippage for the output we needed but we only ran it for heat, a few lights and misc electronics. The voltage was watched closely and once the rpm was set for 125 volts it was very steady. The parts minus the generator were about $200. Wide open throttle will run it at 540. With the PTO in high range the engine is running about 1/2 throttle.
/ DIY PTO Generator #18
Try searching Craigs List OFTEN.
I picked up a barely used 12KW Winco for $600 and about a week later saw a 20KW for about $900.
/ DIY PTO Generator #19
There are some people that try to impress other folk with how smart, capable, fit and great warriors they are. By having all manner of hazards about them and be alive to tell the tale.
I see a lazy cheapskate that is in denial.
Set the speed to Frequency, not voltage. It's an AC machine, not DC.
/ DIY PTO Generator #20
Say what you will but it works like a charm and does exactly what I need. You can throw money around to have all the shinny new stuff you want. When we were with out power for a week. There was no gasoline to be bought only siphoned out of the vehicles. Oh no that's not safe either. I have plenty of home heating oil, and a small tractor that did what I needed. No extra engine to maintain. Why would you really need 14k in an emergency which is what this was built for? Denial hahaha what a trip.
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
TANK MANIFOLD (A58214)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
