JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
Having some issues with this LoadMatch thing... I ordered the Automotive Style Cruise/Speed/Load system, so it should be there..
I looked in manual, and it says to activate load match.. you go to the display, hold the display change button until it says "RELEASE" then it will show either "Coast or Load", and use the turn signal buttons to change it.. but on mine, using the turn signal doesnt change anything.. it just stays at "Cruise".. if I hit the display button again it goes to the settings for LONG and SHORT that I can change with the turn signal switch.
If I just hit the display button and thumb through the displays, I see LOADOFF.. and I can hit the button with the wheel symbol to the "1" position, and it changes to "LOADON"... but, when I press the forward pedal having the throttle all the way down; it never increases.. so I'm thinking it isn't working -- unless I'm missing something?
I looked on the system configuration, and it is set to "04 11".
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #2
If you have the automotive style cruise option you use the LoadMatch physical switch to turn on/off LoadMatch. It is located on the left hand side of the dash. It is noticeable when it is on or off. I don't understand what you mean with your reference to the throttle.
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #3
I think he is referring to eThrottle. I was confused as well...He clarified that on the "other forum". Where is the eThrottle switch located on the 3x20's?
Looking at his pictures on GTT, it doesn't appear to be there.
Maybe I'm missing the eThrottle? I figured it was included in the automotive package.
I'm trying to make my forward pedal control throttle too? So by pressing to go faster it will automatically increase engine rpm.
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #5
I see, that makes sense to me now. The automotive cruise package does not include eThrottle. I am not sure if eThrottle is available on the 3x20 series?
Hmm I was thinking I saw eThrottle... But maybe not? Anyone know if its even available on the 3520? Figured so since its an eHydro?
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #7
I'm wondering now too... But the document I linked on the "other forum" was from the 3520 manual on Deere's website.
Yeah I saw that.. Had the eThrottle far left on console top level switches for a JD 3520.... Hmmm..
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #9
Hiya,
There is no "e-throttle" on the 3x20 series that I know of, only on the 45-4720's if memory serves. Loadmatch is not a autothrottle system like on the Kubota Grand L series, it's more like a governor system.
Think of it like limiting you to 80% throttle capacity when it's on and the load is low, as you load the tractor greater than 80%, the loadmatch system controls the last 20% of the throttle for you, since the loadmatch system is able to respond to conditions faster than you are, it appears that the tractor is carrying the load "normally" however in reality it's matching the throttle to the load so you don't have to.
Tom
Hiya,
Tom
Thanks Tom!
LoadMatch seems amazing -- can't wait to put it to use. I be the eThrottle and LoadMatch would work even more amazing together! Too bad it's not available on the 3x20 tractors! I was first looking at a 4720 -- so I guess I just got my features mixed up, unfortunately! I was looking forward to it!
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #11
There is an electronic throttle control mounted on the motor on all the machines. If there is no e throttle option, what purpose does it serve? From my understanding, load match regulates transmission speed
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #12
Yes, that is the way Load Match on my 2007 3720 and 2010 4320 functions. Newer machines may be different.
So would that mean that eThrottle/AutoThrottle should be available on all machines? Dealer said that the eThrottle is ONLY available on the AutoHST not the eHydro... sounds... IDK.. ??
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #14
Dealer may be wrong, as mine is. According to all other sources than them -including TractorData- ALL 4720's with eHydro have eThrottle and many other 3x20 and 4x20 have it too. However JD themselves don't make this very clear and, at least in the 4720, you won't find any eThrottle switch anywhere and the manual never mentions it by name. This feature appears to be concealed within the depths of the rather confusing cruise control options and somewhat interfaced with one -or more- of the "Match" systems the use of which, apart from MotionMatch, is still unclear to me even after 8 years of ownership. I find my 5105M much simpler to operate despite having a lot more controls. I would appreciate if someone could tell me in non-rocket scientist terms how this eThrottle thing is enabled on its own. By that I mean not having to set 17 other features in motion in order to get at it. The manual is useless on this and as for my dealer he says "eThrottle is for yard tractors I think, some have that switch". In other words he doesn't know jack sh.. about it.
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #15
the e-throttle works as such: when you push the hydro peddle in forward or reverse, it raises rpms like you were driving a car. almost works like the power reverser trans. But as already mentioned, only available in the 4thousand twenty series tractor.
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #16
Karl, on the 4520 and 4720 equipped with the upgraded cruise swithches you get a separate switch to turn off/on the auto throttle function. Seems I remember that when installing the upgrade that you remove the existing cruise switch and it is replaced with three other switches. If you don't have the upgraded switches you may not be able to use the auto throttle function. It is a good feature and I use it most of the time except for things such as tilling or brush mowing where a constant pto speed is more desirable.
/ JD 3520 - SpeedMatch / LoadMatch / MotionMatch Issue #17
eThrottle (auto throttle) is standard equipment on 4520's and 4720's only. It doesn't matter which cruise control you have, as long as all the switches have a place. I'm not sure what year the option became available though. I surmised that it was when the engine HP jumped up and became all electronically governed (maybe 2009???). The new operators manual DOES mention it.
As does the service manual. I don't buy into the notion that the feature exists on "all 4x20's with eHydro", and that it just has to be "enabled".
I've attached the schematic from my service manual. It shows where the switch goes, in case someone wants to experiment.
It is a great feature that, to me, is needed to really make the "LoadMatch" feature shine.
  • ethrottle.pdf
Unused 2021 UM Ripper Bedder 432 Toolbar Subsoiler Tractor Attachment (A66734)
Unused 2021 UM...
CAT 345CL Track Adjusters (A68134)
CAT 345CL Track...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
2008 TROXELL 130BBL VAC TRAILER (A67714)
2008 TROXELL...
