FEL removal
/ FEL removal #21
Having trouble re-connecting 2 of the hydraulic lines. Too much pressure to connect. Any way to relieve the pressure?
/ FEL removal #22
Push hose ends against the tire.
/ FEL removal #23
Ballpeen hammer and flat punch, hit the center pin on the male and female end to relieve pressure. Just use a rag around it b/c the hydro fluid will spray.
/ FEL removal #24
Watch your eyes when it goes off.Wear glasses
/ FEL removal #25
For future reference, if you're going to disconnect the FEL get it to where you are about to disconnect the lines, and with the tractor turned off, move the joystick in every direction to relieve the pressure in the lines, THEN disconnect the lines.
/ FEL removal #26
ive also noticed that if i wait for the tractor to cool down...like the next day. the hoses will press in without any issue. the hydraulic temps in the tractor have expanded the fluids and increased the pressure (i am guessing) and when it cools the pressures decrease.
i also disconnect and leave my loader in the shade now on. dont have issues with pressure differential any more.
/ FEL removal #28
Here is a gadget you should have.
Simple Tool Solves Hydraulic Pressure Problems
A simple tool invented by George Waite makes releasing pressurized hydraulic couplers as easy as turning on a water faucet. Waite's Hydraulic Pressure Relief Tool works like pliers to grip the valve end. Turn a simple tap on one side of the pliers, and it slowly presses on the male fitting, gradually releasing pressure
Company: WaiteÆs Tools
PO Box 66
City: ATWOOD
State: CO
Zip: 80722
Country: USA
Email: bramma@kci.net
Phone: 970 522 5696
I bought one for $34 and it is better than hitting the Hyd coupler with a hammer. I have no connection with George Waite, just a satisfied customer
/ FEL removal #29
This may sound like overkill to some; but always wear safety glasses/goggles/facemask when working on machinery. Dirt and metal fly when struck. They also fall when working under stuff. Now add salt, oil, and corrosives and you can seriously and permanently injure yourself. Hydraulic lines can be really dangerous too. If the line's pressurized, you can get a jet that slices through flesh like a razor sharp scalpel. Spent 20+ years in USAF vehicle maintenance and saw my share of pretty horrific accidents. And every one of them could have been prevented, or mitigated with correctly worn safety equipment.
/ FEL removal #31
[QUOTE Hydraulic lines can be really dangerous too. If the line's pressurized, you can get a jet that slices through flesh like a razor sharp scalpel. [/QUOTE]
That is why the little Waite's tool makes so much sense, I have gotten sprayed with high pressure hyd fluid while hitting the hose with a soft hammer even with a rag over the end.
/ FEL removal #32
Company: Waiteニs Tools
PO Box 66
City: ATWOOD
State: CO
Zip: 80722
Country: USA
Phone: 970 522 5696
DITTO, ME TOO :)
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
CAT CB34 (A60462)
CAT CB34 (A60462)
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2022 John Deere 410R Sprayer (A63111)
2022 John Deere...
