Kubota B6100 4x4 with new threads and shoes
   / Kubota B6100 4x4 with new threads and shoes
KubotainNH Your set up is the same block I have for the factory port. David, . . . . I think you have the switch under the seat?! That would be a pain switching back and fort. I have both so I would be able to use the block on the port like Kubotain does and still have the aux pump dedicated to steering. The loader dual valve is PB with a output return as well. Then if I ever build a grapple fork I can use the under seat valve to operate that.
Thanks for the thought process guys!
   / Kubota B6100 4x4 with new threads and shoes #12
Personally I think I would use your aux pump for the loader, I also have a rear blade and I am forever switching knobs and levers going from Loader to 3PTH blade.
I never have to touch that knob. The 3 point hitch is in line after my FEL. Works like a champ.
   / Kubota B6100 4x4 with new threads and shoes #13
Hi Smokinhart. Would you be able to provide information on what you are running for wheels and tires on your B6100? I have the same model machine and would love to bolt on the same wheel and tire combo as my turf tires aren't cutting and I don't want to put on ag tires. Any info you could provide would be much appreciated.
   / Kubota B6100 4x4 with new threads and shoes #14
Just about done and ready to mount the loader on the new refurb B6100:thumbsup::cool::thumbsup:
After
[/IMG]
Been a fun and challenging build.
That thing looks like a beast. Job well done.
   / Kubota B6100 4x4 with new threads and shoes #15
Thats a nice tractor,job well done:thumbsup:
   / Kubota B6100 4x4 with new threads and shoes #16
Awesome job on the restoration! That makes me want to spend more time with my b7100. What loader are you putting on it?
   / Kubota B6100 4x4 with new threads and shoes #17
I had a B6100 years ago. That's what sold me on Kubota. Those things are tanks! Nice job.
Thanks for the kudos.
I put an ARK 515 loader on it after those pictures were taken several years ago. 78" lift 42" bucket and front mounted crankshaft pump. New three spool valve . Works well ... Even built a belly hydraulic reserve tank in the frame. I'll post some current pics soon. I don't use the tractor much and even considered selling it this spring. If I decide to let it go I'll post on the appropriate board here to let y'all know ...
10 x16.5 skid loader tires on back and 6x10 loader tires up front. 6 ply are tough to mount on these rims! Kept the gear ratio within 2% if I remember to avoid drive shaft wrap differences.
   / Kubota B6100 4x4 with new threads and shoes #20
Welcome back smokinhart. You did a great job on that tractor. And I'll ask for SilverLakeFab, what wheels did you mount the tires on?
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2006 International 9400i (A51039)
2006 International...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
