M7040 "hissing" noise from under seat?
   / M7040 "hissing" noise from under seat? #41
I suspect it's an easy answer. I'll bet the dealer knows.
Yep I will call and see what they can tell me.
   / M7040 "hissing" noise from under seat? #43
I adjusted the 3 point hitch like the dealer told me and added some hydraulic fluid just to be on the safe side and its not as noticeable I'm just not sure if the hydraulic fluid should be bubbling while the tractor is ideling
   / M7040 "hissing" noise from under seat? #45
You know, I had to adjust my draft control and three point linkage on an MX5100 last summer and when I had it incorrectly adjusted I heard a "hissing" type sound. It was more like a "straining" sound from the hydrauliics and it was under the seat by the draft control hydraulic levers. Just remembered that. After adjusting correctly, the sound went away.
Watch, after all this you'll probably find a snake under the seat...:laughing:
That's about my luck for sure lol
   / M7040 "hissing" noise from under seat? #47
I finally remembered(Oldtimers disease) to look in my M7040's hyd filler hole with engine running and it's "bubblely" also. So I suppose this is inherent condition with the orange paint.
Ok that's good to hear I appreciate the help a lot! Thanks!
   / M7040 "hissing" noise from under seat? #49
Push down on your 4x4 lever...
   / M7040 "hissing" noise from under seat? #50
I have a 2010 7040 with the mechanical shuttle transmission. My tractor will make a similar noise from that valve region when it's warm (hissing/ slightly buzzing sound). I have a couple hundred hours or so on it and no problems. I believe it's just the fluid running through the system, perhaps running over a rough edge of a fitting or something.
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2008 FORD F-650 (A50854)
2008 FORD F-650...
2009 International Frazer Bilt X-514 Ambulance (A49461)
2009 International...
