69 model ford 4000 hard starting
/ 69 model ford 4000 hard starting #1
2006gmcdmax
Gold Member
Augusta, GA
Many but mostly ford diesels or ihc or jds
My ford 4000 runs great cranks right up when it's warm uses no oil what so ever, but the tractor if you leave the fuel shut off in as in the run position it takes forever to start usually kills the battery, but if you pull it out an leave it out it'll crank right up the next day. what's my problem I've fixed every fuel leak in it even changed an injector? I've redone all the leaking on the injection pump top too
/ 69 model ford 4000 hard starting #2
The only thing I can think of is that it is leaking back from the injectors and through the pump when the shut lever off isn't in the OFF position. There must be an air leak somewhere.
Do you think one of the injector lines would cause this or maybe one of the injectors isn't sealing completely I've put one injector in it because it was smoking at idle cleared up now its smoking again
I wonder if I should get new injector lines one is retarded and u have to force it when tightening its after market so it doesn't fit good
/ 69 model ford 4000 hard starting #5
ay weeping around the injector lines?
spray everything down with carb cleaner and let dry.. then after setting.. look for wet oily diesel seepage.
do this ont he injector pump.. and hard lines as well.
I founds it it was the metering valve
Almost finished
/ 69 model ford 4000 hard starting #8
man your shop had nice carpet! :)
/ 69 model ford 4000 hard starting #10
very true!
Haha nice old school carpet
Yeah that's to help with the quality
Well it's the only thig else I could think of beside changing the pump but my pump sprays pretty good when bleeding fuel but mine is acting up again and it's hard to start
/ 69 model ford 4000 hard starting #15
So how did you fix it?
I'm not sure what's going on still I think the feed line coming into the pump is leaking
Finally fixed it yesterday it kept loosing prime and getting air in the lines. So I thought about it yesterday at work and said I haven't checked the oil in a bit. so I checked it it seemed thin. I smelled it smelled like diesel. Then I knew exactly what it was the oil seal in front of the pump was bad
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
RYOBI GRINDER ON STAND (A67714)
RYOBI GRINDER ON...
20' Container (A64912)
2019 Yanmar ViO35 Midi Excavator (A66734)
2019 Yanmar ViO35...
