case 446
/ case 446 #1
winston88
REEDSBURG,WI
does anyone or can anyone help me find out how to hook up a tiller on the back of this 446.i had a 444 at one time and took it all apart,but did not remember how it went back together.in need a pic, of it . is thr a place to go to to see it.thnks for help if u can.winston
/ case 446 #2
If you have a BASIC tractor, then you must have the hydraulic PTO Kit mounted behind the seat to provide power to the tiller. You must also have one of the two optional hitches. The Sleeve Hitch will couple directly to the tiller but the 3 point hitch must be equipped with a F-27 Sleeve Hitch Adapter for the tiller to slide on to. If you need more information than that, then send me a PM.
/ case 446 #6
I am not convinced that Eastman will have the correct PTO Kit available for your 448. The last 448 rolled down the assembly line in 1988 which is 25 years ago. You would be far better off seeking a used PTO kit on e-Bay and having it shipped to you by USPS. Customs will charge you 13% HST on the Canadian dollar value plus another $5.00 fee to the Post Office for collecting the HST. There are not duties on this item because it was made in the USA and falls under the Free Trade Act.
You have a long wheelbase tractor. Therefore, you need a complete PTO kit from a 444, 446 or 448 made for the 1980 model year or later, so that the lines that run from the PTO valve on the rear to the travel/lift valve underneath the tractor are the correct length.
In the alternative..........you might consider purchasing everything except the steel lines. It would be far less costly to ship because the package would be substantially smaller. Once it arrives, it is a simple task to bolt the valve bracket to the rear of your tractor. If you have the use of a trailer that could transport the tractor to a local hydraulics shop, two hoses could be made to take the place of the steel lines. Having the tractor right at the shop would ensure that the most efficient hose fittings are used and the hose lengths are correct. Currently, used PTO kits on e-Bay bring around the 200 dollar figure. Sometimes more, sometimes less. The current price for a PTO kit that fits the newest tractors, sells for $850.00 US.
If you see one on e-Bay that interests you, feel free to send me an e-mail. I will look at it for you to make sure it will work on your tractor.
/ case 446 #7
Thanks for the info!
There's a complete transaxle with the pump for cheap on ebay right now but the shipping would be nuts...I can wait though. Thanks again.
/ case 446 #8
I do not understand your reply. You asked where someone would buy a PTO kit. I gave you that information. A "complete transaxle with the pump" has absolutely nothing to do with a PTO kit.
/ case 446 #9
My apologies...I am new at this and clearly thought I was looking at something that WAS related to the PTO kit. Thanks for the info and correction.
/ case 446 #10
The rear PTO kit is an optional piece of equipment that extends the use of the tractor by allowing the owner to power attachments such as a log splitter, rough cut field mower, finishing mower, vacuum units, chipper/shredder and rototiller. However, some of these attachments require a hitch to be added to the tractor so that the attachment functions correctly. It all depends on the attachment. Hitches are also available as a used item on e-bay. Your chances of finding either a hitch or PTO kit for sale in Canada are slim to none.
/ case 446 #11
It looks like some case tractors had hydraullic tillers.
This person has a hydraullic 3 pt hitch, and a hydraullic powered tiller.
- Case and Ingersoll Garden Tractors
You might also be able to get a hydraullic drive motor powering a PTO, although the length may be an issue.
/ case 446 #12
All of this series of Case garden tractors use hydraulic attachments that hydrive listed above.
[/QUOTE]This person has a hydraullic 3 pt hitch, and a hydraullic powered tiller.
- Case and Ingersoll Garden Tractors [/QUOTE]
[/QUOTE]You might also be able to get a hydraullic drive motor powering a PTO, although the length may be an issue.[/QUOTE]
This is the PTO needed. It is not a mechanical shaft like a farm tractor.
/ case 446 #13
Clifford K has kindly provided a link to a gallery of photos that depict Charlie's early 446 Case that he has modified extensively. Charlie added his own flow control to the left side of the dash tower and a selector valve to the right side. The three point hitch is one that Charlie made for his tractor. The big red tall thing in the final photo is actually a hydraulic post hole digger Charlie designed and built for his tractor. That is the beauty of the Case hydraulic drive garden tractors. All sorts of hydraulic devices can be powered off the rear PTO valve.
Many thanks to Xfaxman for the three photos he supplied. The left one shows a factory J-26 three point hitch with the F-27 Sleeve Hitch Adapter connected to it. With those two items, the owner can hook up a wide array of attachments. The PTO valve is shown on the left side of the tractor next to the left fender and just behind the seat. The middle photo shows a PTO Kit by itself. There are the two long steel hydraulic lines, the mounting bracket with the valve attached and the hydraulic looping hose with quick couplers.
The right hand photo shows the PTO kit installed on a typical tractor by itself.
If you walked into a Case dealer back in the day, your Bill of Sale would show the price you paid for the basic tractor because that is how these tractors were sold. You then selected which size of mower deck you wanted and a separate price would be shown for that. If you wished to be able to rototill your garden, then you would need a sleeve hitch, a rear PTO kit to power the tiller and the Case H or J-70 hydraulic drive tiller. In addition, the dealer would have strongly recommended a D-10 wheel weight kit for the rear wheels, tire chains, a Flow Control Valve for better slow-speed control and a Front Weight kit to balance off the weight of the rear mounted tiller. If you want AG style bar tread tires instead of the Turf tires, then those could be had at the time of purchase.
The complete line of Brinly-Hardy aftermarket implements were available from the Case dealer. Therefore, single-furrow ploughs, single and double disc harrows, spring-tooth harrows, lawn rollers, aerators, seed planters, fertilizer spreaders, tool bars, thatchers and so forth could be had. Other suppliers to Case such as Hudson offered spraying equipment. There were also front mounted power brooms for sweeping, dump carts, snow blowers, utility blades for snow and dirt moving. There are many that I have not listed. There was no need for a mechanical PTO at the rear but there was a front-mounted 540 PTO that could power grain augers and hay elevators. Most of these attachments could be used on any of the Case garden tractors.
/ case 446 #14
So, what the "kit" is essentially a hydraulic control valve, connected to the main hydraulic system for the tractor.
There would be 3 types of hydraulic valves. A bucket uses an intermittant valve.
A hydraulic motor would need to stay on or off, and possibly adjust for speed.
A 3 pt hitch is usually positional in some fashion, but could be done with the intermittant valve.
What about these vales off of a Case 155 tractor?
Case 155 Tractor Hydraulic Control Valve | eBay
Case 155 Tractor Hydraulic Drive Control Valve | eBay
You would need to add an appropriate handle, as well as hoses.
I'm also seeing valves that look like this, but I think it may be for something different.
Case 446 Tractor Hydraulic Control Valve | eBay
/ case 446 #15
The first three e-Bay offerings are travel valves removed from 155 Case garden tractors. These are motor control valves that allow the flow of oil to be metered out to the drive motor starting with a small amount to full output. The purpose is to control the ground speed of the tractor as well as the direction. They are unsuitable for use as a PTO valve because the 155 hydraulic system is 1600 PSI max. I have doubts whether the relief in those valves could be adjusted to the 2200 PSI needed. It simply isn't worth all the hassle to try and make it work.
The last e-Bay offering is for a regular Travel/Lift valve used sometime in the early 80's. While this valve does have a relief that could be adjusted higher, you also have the lift spool in that casting. If you have no need for another spool to control a 575 PSI hydraulic circuit, then what's the point? With this valve, you have to find a suitable place to mount it and then you have to create control handles for it that will lock in the wide open position in both directions.
An OEM PTO valve is designed as an On-Off-On switch. The spools are not machined to meter oil. They are designed to go from full off to full on because the motors powering the attachments are supposed to run with 100 percent oil flow at all times. Granted... no one likes shelling out 200 bucks for a PTO kit plus the shipping but.. that's the current price of admission to the amusement park. Either pay it or return home to your swing in the backyard. Keep in mind that a new Ingersoll basic tractor alone is 8000 bucks and once you start adding options and attachments, it goes up rapidly from there. If you buy a used Mercedes-Benz, the parts are not discounted just because your Benz is 20 years old and only worth 1500 dollars. I'm not trying to be a smart-***. I'm just telling it as it is. You are either in this snack bracket or you are not.
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59914)
2022 GREAT DANE...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
Morbark M12RX Wood Chipper (A63689)
Morbark M12RX Wood...
Commercial 500 Watt Generator (A65579)
Commercial 500...
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
