Trailer Questions
/ Trailer Questions #1
B7510HSD
Kamiah,ID
Kubota B2601
So the local trailer place say they have angle steel frame and for $100 more c channel frame is it worth it?
/ Trailer Questions #2
Yes. Look up on google the strenth of various steel sizes in angle an C.
Chris
/ Trailer Questions #3
C Channel will be a good deal stronger. I would spend the extra cash
/ Trailer Questions
Thanks guys will do research!
/ Trailer Questions
Not enough Info. Angle is probably ok for hauling lawn mowers and other light weight stuff. What are you hauling? What size type trailer are you looking at?
Ron
Looking at an 18' car hauler for my Kubota B7510 w/loader and backhoe...
/ Trailer Questions #7
/ Trailer Questions
Steve.....don't know where you're looking to purchase but check out Top Notch Trailers in Rochester. I bought a 16 ft. from them several years back.....good product.....reasonable price and I've hauled cars from So. Calif. and my tractor all over the place. Purchased direct from factory saved me some money.
Top Notch Trailers, Rochester, WA - serving Olympia, Centralia, Washington and neighboring states Good luck.:thumbsup:
Thanks that is where I have been looking I was going to check out Bulldog in Chehalis also....
/ Trailer Questions #9
I think I'd go with channel iron, I-Beam, or tube steel.
Also note there is a structural grade of channel iron and a not so structural grade. With the structural channel iron, the ends are thicker than the webbing, and tapered. The other channel would be more like bent flat steel.
My little 8' Haulin trailer has the bent channel, and it makes a nice light utility trailer, but You'd probably want something more substantial for your car/tractor trailer.
Your Kubota is pretty small without bucket, backhoe, weights, fluid filled tires, etc. If the company is building the trailer from scratch, you might try to get the fully accessorized tractor weight and give it to the manufacturer. Also, whether you will in fact carry cars, and what type.
/ Trailer Questions #10
Thinking about bulldogs.
I prefer the bulldog style trailer hitches. The are easy to use, and quite secure.
You can also get surge brakes, in the trailer hitch which might not be a bad idea if you don't have electric brakes.
/ Trailer Questions
Thanks for all the suggestions there is alot to think about!!
2014 Ford F-550 (A55973)
2014 Ford F-550...
2025 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
Merco Stainless Steel Commercial Warmer (A60352)
Merco Stainless...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2020 International LT625 48" Sleeper (A62613)
2020 International...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
