M7040 "hissing" noise from under seat?
   / M7040 "hissing" noise from under seat? #1
nauxier16
Red Bush, Ky
2013 Kubota M7040 4wd Hydraulic Shuttle
Hey guys I have a new M7040 4x4 Hydraulic shuttle and I have noticed that it has what sounds like a hissing noise or like an air leak coming from under the seat but everything works great and all the fluid levels are good, i'm not sure if its fluid bypassing a valve or what, i'm not sure if this is a problem or a common thing on these, I was just wondering if you all could help.
Thanks!
   / M7040 "hissing" noise from under seat? #2
I'm thinking rattler?:) Or maybe a cottonmouth?
Have no idea but thought I'd throw in some humor.
Could you have a slow air leak in a tire? Suspension seat leak?
Enjoy your new tractor.
   / M7040 "hissing" noise from under seat? #3
Check that your 3pt is not bypassing at the top of the lift.
What is the best way to check it and if it is doing that how do I fix it? I kinda think its something like whatyour talking about.
   / M7040 "hissing" noise from under seat? #5
do you have an air ride seat that has a leak? Do you hear an air pump continuously running?
No it doesn't have an air ride seat, I'm not aware of it having an air pump
   / M7040 "hissing" noise from under seat? #7
Move 3 pt control lever forward just a little and see if the noise goes away. It's possible the 3 pt is raised to it's upper limit and control valve isn't going into neutral position. If lowering 3 pt stops the hissing noise then I'll guess "feedback rod" is out of adjustment.
Ok thanks a lot, I will try it when I get home from work tonight and I will see if it works.
I moved the 3 point hitch up and down and the sound would stop but when I would raise or lower the hitch it was still noticeable just not as bad
   / M7040 "hissing" noise from under seat? #10
Sounds like you may have had too much chili:laughing:
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
Unused Delta Crash...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A51039)
2004 Capacity Yard...
2022 RAM 2500 (A50854)
