Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Shopping for my first ZTR. Mowing 2-3 acres per week, and every other week mowing an additional 3 acres. Relatively flat, grass is in decent condition but it's not a Scott's lawn and I'm not trying to make it that way. I mow around lots of trees, flower beds, landscape gardens, gardens, chickens, children, etc :confused2: I live in Michigan and will mow for maybe 30 weeks a year at best. I'm guessing 150 hrs per year at most.
Most people that I know who have used a certain brand are pretty loyal to that brand and believe whatever propaganda that their respective manufacturer tells them. So, I'm hoping that someone here can give me an opinion on their experiences with the below brands and tell me something I haven't found in general research. They're all priced relatively close to each other. They all use 1 of 3 identical engines, they all use pretty much the same transmission, tires, belts, gas tanks, etc etc etc. It seems like I'm basically buying a brand name and a mowing deck, and a color:laughing:
Here's what I'm finding in my area:
  • Bobcat FastCat Pro 61", Kaw FX 24hp, ZT-3400 trans, $6299.
  • eXmark Pioneer S 60", Kohler 27hp, Zt-3400 trans, $6999.
  • Dixie Chopper Magnum 2760 61" (last year's close-out model), ZT-3400 trans, $5599.
  • Scag Freedom Z 61", Briggs 30hp (last years) for $6509 or Kaw 24hp (this years) for $7009.
  • Grasshopper 226v 61", Kohler 27hp, not sure on trans, $6923.
  • Hustler FasTrak 60" Kaw FS or FasTrak Super Duty 60" Kaw FX, looks like both use ZT-3100 trans, $5794 or $6479.
  • Also looked (online) at a Dixon Ultra 61" OR the Husqvarna 6128 61", both with 27hp Kohler, ZT-3400 trans, and under $4999... but I can't find much about them on the forums and they look less refined than the others.
They're all pretty similar, all close in price, all have similar financing...
I'd like to hear specific reasons why I should AVOID any of these particular mowers, OR why I should buy 1 over another?
Thanks in advance, Tim.
fetch_file
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #2
I have a Dixie chopper silver eagle and really do like it. Mine is the 27hp with 60 inch cut. This will be my third year with absolutely no problems. I cut around 4 acres a week, 3 is mine and about 1 acre for my mama. I have around 130 hours using it 2 full summers. They are really fast. I had a Husqvarna commercial before that. Only problem kept throwing pulley off and tearing belt off. The main thing get the commercial mower made so much better.
Sent from my iPhone using TractorByNet
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #3
I may be wrong but aren't Exmark and Bobcat one of the same?
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #4
I have been mowing commerical for 14 years now, and have used Kubotas, Exmarks, and now Deeres. I will say there is no "perfect" machine. Find a dealer with a good service department, one that is somewhat close to you. Go sit and drive every machine your considering. Just cause they look the same, they will handle different and your visability around the machine may be different. Look at all the service points on the machines. Also, I would recommend you pay attention to tire sizes on the mowers, I prefer 23" tall rears or larger, and also some have smaller narrower fronts. Larger is better..
Also, of those you posted pictures of, I would stay away from the Husqvarna, I dont like the discharge side, too small of opening. Also look how much cheaper $ it is.. Of those you posted, I would look at the Exmark or Hustler. They should be sold and serviced by good reputable dealers. Take care of the machine and it will hold its value better than some of those others.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #5
Back in the late 90s and early 2000s, Exmark, Toro, Deere, Yazzo Keys, and one other, could have been Bobcat, all used the same tractor part, but the mower decks were all different designs. For the last several years, Exmark and Toro are the only two twins out there.. Each make their own decks, but the tractor part are the same between the two brands.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #6
See if you have a Ferris dealer by you. Better ride and much better machine but pricey
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #7
I have an eXmarx lazer 60" with a diesel 3 cyl Diahatsu label (Briggs/Stratton. While I realize the extra cost of the diesel it is in a class unto itself
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #8
Check out the Ferris IS2000z. It's the one you missed in your list and yes...I agree when you buy a zt, your just getting their brand name, mower deck and frame design. The frame is the one place Ferris is different from all those you listed. It has 4 wheel suspension and yes...its worth the money. It'll run around the high 8s.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #9
Just stay away from the later ones with the Kubota diesel engine, they are nothing but trouble. I had 4 different ones and were always at the dealership for repairs. Not abuse, just poor designs.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #10
I prefer a mower that does not crush down the grass before you try to cut it. I have an old Jacobsen 3 wheel mower that has the deck out front and ahead of the wheels that support the mower. So a mower with very thin front (ahead of the deck) support wheels to minimize compaction of the grass is preferred. No one makes a mower like that nowadays.
I use a 7' JD rotary brush/grass mower for field mowing but the tractor wheels crush down the grass (a foot wide for each rear wheel) so the mower can't cut it!
Dennis
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #11
I have a Scag Wildcat with a liquid cooled Kawasaki engine. I looked at all the mowers in my area and everything about the Scag was heavier, bigger and in my opinion, stronger. The blades are super easy to take off, the seat is the most comfortable that I sat in and the dealer has all the parts in stock. I don't have any experience with any of the other machines, so I can't say if mine is better or not, but I'm very pleased with Scag and would buy another.
Number one, most important thing of any mower or tractor is the dealer. If you have a great dealer, go with that brand.
Eddie
Eddie
I like the Scag... but the one I'm looking at is the Freedom-Z. I think yours is a step or 2 up.
My Uncle has an older DC also and loves his. The one I found (last years model Magnum 2760) is a steal compared to the others at $5599... but it uses a Briggs and I'm not sure I"m happy about that.
I would LOVE to get a Diesel, especially since I can write off the fuel (my tractor fuel). However, the up-front cost is MUCH higher. Takes it out of my price range as I'm really aiming around $6500. I think the diesel's start at around $10k.
BobCat is by itself... made by Schiller Equip or something like that, out of Wisconsin I think. I also spoke with 2 other dealers (Big Dog and BadBoy) that are also around 25+ miles away, here's what they quoted me:
BigDog R-Series 60". KawFR691, ZT-3100, $6225
BigDog R-Diablo series 60". KawFX730, ZT-3400, $7845 (with the "Flex-Forks" added in the cost)... He said the BigDog's were Red Hustlers and usually 1-year behind the Hustler twin.
BadBoy CZT Elite 60", KawFS726, ZT-3400, $7662.
So, only the BigDog R-Series with a smaller engine than the others I'm shopping, was competitive in price to the rest of the list.
Good point on the tires... and I was thinking of staying away from the Husq/Dixon anyhow, they look much "cheaper".
Dennis
Currently, I'm using a mid-90's Ford-NH CM272 72" Commercial Front Mower. It has a 27hp Shibaura Diesel. It's nice, and it cuts big spaces quick. However, it's VERY heavy and LONG, so it's not nearly as maneuverable around tight spots, and it ruts my lawn if/when it's damp. Also, it has very high hours... I already had to spend some money last year on it to replace a head-gasket (wasn't cheap) and parts are getting more and more difficult to find. I'm going to put it up for sale here in a couple weeks and get away from it.
I'll check into the Ferris units too and get some pricing.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #13
Dennis
You would want the F series John Deere front mounted mower (built like a forklift with a mower in front) with U joint power to the mower deck rather than belts. I think I would prefer one of those to a zero turn, but the price is rather high. If money was no object, that is what I would buy. They are built for maintaining golf courses and work on hills just as well as flat, whereas a ZTR drifts down the slope
Gary... see the last paragraph of my above post. Not to mention that new ones of those are ridiculously expensive!
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #15
I've used Exmark and Hustler mowers commercially... both are very good machines. Scag also has a great reputation. My experience has been to go with Kawasaki motor if at all possible. My current recommendation would be Hustler.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #16
for $6500, I would get a used Kubota diesel mower. I found one 3 yrs ago for $3500 with 700 hrs and it is amazing. I cut 3 acres every week and that old ZD21 60" cut is awesome. my BRL and niece each got a 4000 to 5000 JD and Huscavara when i got my used diesel commercial grade mower and mine looks and runs better than those 2 now after only 3 yrs of use. Consider going quality used commercial grade.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #17
I bought my Scag Wildcat with rear bagger about 3 years ago from a pro lawn guy who prefers JD's to the Scag and so he put it up for sale with only 200 hours on it. I've run it ever since, HARD, and it is bulletproof. It has the basic stock seat without suspension and it is comfortable, but the full suspension seat would be awesome.
A lot of pros around here are driving Xmarks and Scags- Freedom Z's now. I don't see pro lawn care guys using the other brands at all.
Scag is made here in the states- something not found in many other brands. They are solid as rock and somewhat heavy and do want to go where they want on hills.
IMHO, unless you blow away your budget you likely won't find a better mower in the price point you want. you could also go low hour used too, and save a LOT of dough.
Good dealer service is like all machinery- a very important part of the whole purchase package.
Also note that your intended use of 150hours/season is NOTHING as far as commercial use. Some guys will do that in a week's mowing. Scag has a number of acres/day chart; which blows one's mind when you consider how many hours a day they can be run and how much acreage can be cut.
If I were you I'd start with a good used machine with relatively low hours and see what works for you, then upgrade to new in a year or two after deciding what is the best mower for your use/needs. I don't think you need to spend what you are thinking you need to this year; at least not for the number of hours/use/season. JMHO.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #18
Thank you. Google shows a number of that type such as Gravely, Steiner, Ventrac even Kubota has one. The Jacobsen has a drive shaft to the gear box and hydraulic lift so you can actually mow without wheels pressing the turf down. I have a relatively cheap Craftsman mower that I purchased with optional exta wide tires thinking it wouldn't compact the grass as much but didn't work out that way.
Dennis
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #19
TSO,
I don't have any of the above. I use a 6' finish mower behind my 2600 Ford.
However, I do have a couple friends in the commercial mowing business. And, down here, they've already started. :D Really, our normal mowing season generally runs from about Easter through Thanksgiving. From May until October, they run 6 days per week. Four ZTR mowers. They've just about tried them all, and say they get the best results from eXmark, followed closely by Dixie Chopper. (they currently have 3 eXmark and 1 DC)
Hope that helps.
   / Shopping for a new Zero Turn --- this is what I've found so far, INPUT NEEDED #20
TSO,
All of them make good machines, made in the USA and brand selection seems to be more regional.
In the NE, most here run Scag, Exmark, and Ferris and the occasional Kubota and Hustler. Also most of the lawn services have people to run the machines, so ride quality is not the first issus its build quality and longevity, since the owner is not on them 6 hrs a day but has to keep them running to make $.
Virtually all the machines should give you a long service life 1000-1500 hours w/o major issues, and good cut quality so it comes down to if you are running it, how does it feel for you? For ride quality, cut, and performance I got the Ferris (and they make Simplicity ZTR as well) IS2000 based on the suspension and overall construction because I am running it.
If I had a crew running the machines doing 50-60 lawns a week - that's a different paridigm and would come down to cost per unit and less about creature comforts.
Carl
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Toro z turn (A56859)
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
