Non Hydraulic Front End Loader
/ Non Hydraulic Front End Loader #1
Gale Hawkins
Super Star Member
Murray, KY
1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
/ Non Hydraulic Front End Loader #2
it was a lot more work, but some of the power lifts and other things they came up with were ingenious, the one problem was if one was not moving it would not lift, so if you got some thing stuck it was stuck, and usually one would have to dig the implement out by hand with a shovel, enough to move it so the power lift would work, (usually they worked off a drive wheel),
/ Non Hydraulic Front End Loader #3
Many of the old crawlers had cable lift blades. I ran one in the early '60s. It ran off the pto on the back end.
/ Non Hydraulic Front End Loader #4
That thing is cool looking!:shocked:
/ Non Hydraulic Front End Loader #5
Id like to visit that old bone yard.
/ Non Hydraulic Front End Loader #6
I had to do two weeks with the National Guard in 1971 after active duty in the ARMY.
I ran a D-9 Dozer that was cable controled for two weeks! You really had to anticipate lifting or dropping. (the Dozer was AUWSOME! It started on gas and you pulled a knob and it switched over to diesel!)
/ Non Hydraulic Front End Loader #7
If I remember right some of the old duce and a halfs were all fuel which meant they would run on anything combustible.
/ Non Hydraulic Front End Loader #8
The name for them was "Multi-Fuel". I don't remember which fuels but I did drive a bunch of them!
/ Non Hydraulic Front End Loader #11
yes duece's were multi fuel.could run on gas, diesel or jet fuel. jet fuel an diesle are very similar however, if you are going to run gas in a duece and a half, it needs to be mixed with oil and you cant just throw gas in the tank and go. Its not hat big of technology for them. They are maily just diesel engine
/ Non Hydraulic Front End Loader #12
Back in Highschool when my mother had gone back to college I got to use her library card at the college library. There was a book in the ag section that had been printed by Lincoln that and other metal working and supply companies. They had pictures and plans of blades and buckets. for farm tractors. The book was printed in the 40's. All the loaders were cable lifted off the belt pulley and they used a hoist system made from car and truck rear ends. The Traxcavator company that started making the loaders for Cat in the 40's used cables off the belt pulley as well.
I used to hang out in a junk yard when I was a kid that had a 5 old ginpole trucks out of Deuces. He would hoist the old cars up and puncture the tanks and oil pans and catch the oil and old gas in dums. He had it all mixed up gas and oil and would run in in the trucks. The old International dozers that started on gas were easy to start but they didnt like to run hot as the head was weakened by the extra set of gas valves.
/ Non Hydraulic Front End Loader #13
The cable dozers worked well with a good operator , the early hydraulics had many problems..Those old tractors and machines had a really low compression ratio and would run on kerosene mostly , reliable but fussy. The current diesel is far better , at least the mechanical ones are..I have spun a few Rumely tractors over and the sheer pulling power is something to experience. They were not fast just kept pulling hard.
/ Non Hydraulic Front End Loader #14
Can someone explain to me what is a deuce and a half? My dad had two dozers with cable operated blades,an International TD18-A and a Cat D6 8u series,which he taught me to run as a boy in the 60's.
/ Non Hydraulic Front End Loader #15
Two and a half ton military truck. Look up M35 on Wikipedia.
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
2017 Case CX145D (A60462)
2017 Case CX145D...
PALLET OF APPROX (10) SCISSOR LIFT CONTROLLERS (A62131)
PALLET OF APPROX...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
2010 Deere 318D (A62180)
2010 Deere 318D...
John Deere 1025R (A62177)
John Deere 1025R...
